Toyota Sienna Is Only Family Van To Offer All-Wheel Drive - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Toyota News
Toyota News News and discussion related to the Toyota family brand.
Old 10-06-2007, 04:09 PM   #1 (permalink)
THIS SPACE FOR RENT
humanoid's Avatar
Gameroom cash: $902364
View humanoid's Photo Gallery
October 1, 2007 – Torrance, CA - The Toyota Sienna brings the Toyota quality and safety standard to the competitive family van segment and offers one of the only all-wheel drive family vans on the market. The 2008 Sienna is powered by a 266-horsepower 3.5-liter V6 engine, making it one of the most powerful family vans available, as well.
The wide choice of model grades, combined with extensive standard equipment and thoughtful features, makes Sienna a truly outstanding value. The Sienna is available in four model grades: CE, LE, XLE, and the top-of-the-line Limited. All four come in front-wheel drive configuration, and the LE, XLE, and Limited also offer all-wheel-drive. The CE and LE are available in both seven- and eight-passenger configurations; others are seven-passenger models.
A 119.3-inch wheelbase gives Sienna exceptional interior room and a smooth ride. The 36.8-foot turning circle is tighter than for some midsize cars, helping to make the Sienna easily maneuverable.
Sienna remains the only family van to offer an all-wheel drive option. The AWD system employs a center differential to divide engine power 50:50 front and rear. Wheel slippage at either set of wheels automatically transfers more power to the opposite wheels to help keep the Sienna moving forward.
The Sienna's standard DOHC 3.5L V6 produces 266 horsepower at 6,200 rpm and 245 lb.-ft. peak torque at 4,700 rpm. A Dual Variable Valve Timing with intelligence (Dual VVT-i) system operates on both the intake and exhaust valves to ensure optimal performance and efficiency at all engine speeds. The V6 is mated to a five-speed automatic transmission with intelligence (ECT-i). Impressive acceleration gives Sienna the power to merge with confidence. Fuel economy remains excellent for the class, with EPA city/highway gas mileage estimates of 17/23 mpg for front-wheel-drive models and 16/21 mpg for all-wheel-drive models.
Focus on Comfort and Versatility
Sienna delivers exceptional passenger and cargo room, with a focus on intelligent space optimization. The dashboard-mounted gated shifter allows pass-through room between the front seats. Sienna offers two distinctly different second-row seating options that are easy to adjust, tumble, or remove. In its seven-passenger configuration, Sienna features second-row captains chairs with a passenger-side chair that can be repositioned side-to-side, offering either a bench or a bucket arrangement.
The Sienna CE and LE grades offer an eight-passenger configuration. A second-row, three-way split/folding bench includes a Front and Center® middle seat that can be moved nearly 13 inches closer to the front seats, making infants and toddlers in child-seats more accessible to the front passenger. All Sienna models are equipped with a standard versatile 60/40 Split & Stow 3rd Row™ bench seat that folds flat into the floor. Either side of the seat can be stowed separately with low-effort, one-hand operation. With the entire rear seat stowed and the second-row seats removed, four-by-eight foot sheets of plywood can be loaded flat onto the floor.
The Sienna Limited 2WD model offers a power-operated third-row version that makes switching from carrying people to cargo even easier. The LCD screen for the available rear seat entertainment system measures nine inches. In addition, a universal mini-jack port standard on all audio systems allows connectivity to most portable music players.
Sienna delivers a wide range of standard amenities. The Sienna XLE and Limited models respond to the growing demand for even higher levels of comfort and luxury to the minivan segment, with the Limited adding standard leather-trimmed upholstery, a 10-speaker premium sound system, heated front seats and other features.
An available DVD-based satellite navigation system for XLE and Limited models includes a backup camera. The camera automatically projects an image of what its lens can detect behind the vehicle onto the navigation system's LCD screen when reverse gear is engaged.
Family Safety
All seating positions are equipped with three-point seatbelts. Front seat-mounted side airbags and side-curtain airbags covering all three seat rows are standard equipment on all Sienna grades. The LATCH system (Lower Anchor with Tethers for Children) is used in all second-row seating positions.
Sienna has been engineered to provide responsive, confident handling, and all models feature a standard anti-lock brake system (ABS) with Electronic Brake-force Distribution (EBD) and Brake Assist. The Brake Assist feature is designed to determine if the driver is attempting emergency braking and, if the driver has not stepped firmly enough on the brake pedal to engage the ABS, the system applies maximum braking power until pedal pressure is released.
Vehicle Stability Control (VSC) with Traction Control (TRAC) and rear disc brakes are standard on all models. VSC helps the driver maintain control in adverse driving conditions, and the TRAC feature helps reduce tire slippage during acceleration.
The Sienna AWD models come standard with 17-inch run-flat tires on aluminum-alloy wheels. Reinforced sidewalls and a special bead shape enable these tires to be driven with no air pressure for up to 100 miles at speeds up to 55 mph. A spare tire is also available. A direct-type tire pressure monitor system is standard on all Sienna models.
The Toyota Value Standard
Standard equipment in the Sienna CE includes power windows, door locks and mirrors; sliding rear doors with power windows; second-row captains chairs; keyless entry system, and deluxe AM/FM/CD audio system with six speakers.
Comfort, convenience and versatility are assured with a standard tilt/telescopic steering column; dual (front and rear) air conditioning; a folding tray table between the front seats; variable intermittent front and rear windshield wipers; 10 cup holders and four bottle holders; three 12v power outlets, and a heavy-duty rear window defogger with timer.
In addition to, or in place of features on the CE grade, standard equipment for the Sienna LE includes an engine immobilizer; heated power mirrors; roof rails and crossbars; privacy glass; steering wheel-mounted audio controls; cruise control; driver's side power window with auto up/down and jam protection; driver's seat manual-adjustable lumbar support; illuminated vanity mirrors; unique LE seat fabric; a fold-flat front passenger seat, and a six-disc CD changer.
Luxury in a Family Van
The Sienna XLE grade adds a host of desirable comfort and convenience features, including dual power sliding doors and power open/close rear gate; tri-zone (driver/front passenger and rear) climate control with air filter; leather-wrapped steering wheel with audio controls; an eight-way power adjustable driver's seat; removable center console, and unique seat fabric. An overhead console features a trip computer, outside temperature gauge and HomeLink® universal transceiver/garage door opener. The Sienna XLE also offers a standard anti-theft alarm and available leather-trimmed seats and fog lamps.
A memory system for the driver's seat and outside mirrors is standard on the Limited grade and optional for the XLE. The Limited's power-folding mirrors integrate puddle lamps and turn signals. Enhanced audio options include a JBL Synthesis 360-watt AM/FM//CD player with six-disc changer and ten speakers.
The top-of-the-line Sienna Limited brings a true feeling of luxury to this family vehicle. The comprehensive upgrade adds: leather-trimmed seats; second- and third-row sunshades; 17-inch aluminum alloy wheels with 225/60R17 all-season tires; front and rear parking sonar; wood grain and leather-trimmed steering wheel with audio controls; JBL Synthesis AM/FM/CD with six-disc changer and 10-speaker surround sound audio system; heated front seats with adjustable temperature control; chrome exterior accents; windshield wiper de-icer grid, and auto-dimming driver's side mirror and inside rear view mirrors.
Onboard Entertainment and Navigation
A wide selection of optional convenience features enhances Sienna's versatility and comfort. Some of these include a DVD rear seat entertainment system with wireless headphones; navigation system with backup camera; 115v power outlets; second- and third-row sunshades, and a JBL Synthesis AM/FM/CD with six-disc changer and 10-speaker surround sound audio system.
The JBL Synthesis audio system integrates Bluetooth® technology to provide a hands-free communication system when used with a compatible cellular phone. A call can be dialed by using the navigation display screen's keypad, and incoming calls can be answered and ended by pushing a button located on the steering wheel. When receiving a call, the audio system is automatically muted, and the speakers act as the phone receiver and transmitter.
Sienna is assembled exclusively at Toyota Motor Manufacturing, Indiana (TMMI) in Princeton, Ind., with more than 90 percent of its content sourced from North American suppliers. Both the engine and the transmission are assembled at the Toyota Motor Manufacturing powertrain production facility in West Virginia.
Toyota's 36-month/36,000-mile basic new-vehicle limited warranty applies to all components other than normal wear and maintenance items. Additional 60-month warranties cover the powertrain for 60 months/60,000 miles and corrosion perforation for 60 months with no mileage limitation.
This is my sig.
humanoid is offline   Reply With Quote
TOYOTA - an Obsession, a Religion or just Madness? RAV4EVR General Discussion 70 02-22-2008 11:07 AM
Parrot Bluetooth Handsfree Kit with Toyota harness! goldmember Car Parts for Sale 4 11-19-2007 05:51 PM
TOYOTA ENGINES AND OIL SLUDGE - WALL ST JOURNAL bondobondo General Discussion 99 02-02-2007 07:54 PM
Toyota Highlander Hybrid Synergy Drive lyn General Discussion 0 05-17-2006 05:10 AM
Front Wheel Drive To Rear Wheel Drive theman33b Camry & Solara Lounge 15 12-15-2005 04:03 AM
