I agree with Squidward, a turbo charger is more economic than a turbocharger. Actually a turbocharger increases the efficiency of an NA engine, efficiency doesn't mean better mileage. But it means you will need less effort to develop a certain speed.
This is since a turbo charger is extracting that lost power in the exhaust (the heat, which causes it to have pressure), to turn the turbine that will suck in the air.
In a supercharged engine, since the turbine that sucks in air is directly mechanically linked to the engine, you actually burn more fuel to turn it.
You shouldn’t drive for the thrill, but for the pleasure of tasting the control…
