Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Commendable tC 0-60 performance
View Single Post
Old 07-23-2004, 09:27 PM   #12 (permalink)
91MR2quickNA
View 91MR2quickNA's Photo Gallery
Originally posted by Mighty~Mart
what is the max theoritical HP if i were to add the tC S/C to my gen 5 camry?
That depends on the type of pulley you use. Typically the stock pulley is 5psi, which is 200hp. I think you can go up to 13psi or more, but I don't know if the engine internals could take it. The compression ratio is 9.6, which isn't all that good for forced induction but not that bad either. You'd need an intercooler for sure. Since it's a 2.4L, the gains are more prevalent. I'd say 264-280. You'd definitely need an engine build to achieve those numbers, IMO.
I've read that if you severely overheat an aluminum block, it'll warp beyond repair.
Jason
91MR2quickNA is offline   Reply With Quote
