Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Kicker Comp VR's
View Single Post
Old 07-24-2004, 11:19 PM   #6 (permalink)
Luc
View Luc's Photo Gallery
The Comp VR only comes in DVC version. I don't recommend using a 4-channel to run subs, even though it's capable. You won't be getting the most output even in bridged mode. If you get the DVC 4-ohm, you'll be running each sub at 2-ohm or 8-ohm (preferred) bridged. If you get the DVC 2-ohm, then that would be 1-ohm or 4-ohm bridged. You have to check whether each bridged channel will support 2- or 1-ohm loads.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
