Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Roll Center Adjusters...drifter's best friend...
View Single Post
Old 05-23-2002, 01:36 AM   #1 (permalink)
driiift_hachiroku
DriftStar.com KingPin
View driiift_hachiroku's Photo Gallery
besides an LSD, a Roll Center Adjuster is one of the essential elements to tuning your AE86 suspension.
An RCA goes in between your strut casing and the lower-control arm on the front suspension. It's basically a block that returns your control arms back to "normal" position, instead of parallel to the ground on a lowered car.
There are some Negative Roll Center Adjusters that are set up to add more negative camber and front track width. I installed a BattleVersion NRCA today, and you can really tell the difference.
Problems that it alleviates:
Bumpsteer
Bodyroll
Understeer on turn-in
steering effort
and NRCA's defintely make the AE86 look mean on full DEMONCAMBER setting.
Jover
http://www.driftstar.com
1985 AE86 Corolla GTS Coupe
4AGZE (Supercharged)
driiift_hachiroku is offline   Reply With Quote
