Originally posted by LonelyDriver
If you wait awhile. TRD is working with Vortech to produce a kit that produces upto 300 HP.
I think 300 hp on this engine would be impossible without lowering the compression via a thicker head gasket and/or turbo pistons. The compression ratio @ stock is 9.2. Thats just to high for anything more then 8 or 9 psi.You would have to pump 25psi and that would might get you close to 300hp but the compression would be way too high to run on pump gas.
I would like to know where you heard or read this.
