Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Need stock amp help
View Single Post
Old 08-03-2004, 04:57 PM   #2 (permalink)
Luc
View Luc's Photo Gallery
You could use the OEM/stock amp to feed off the preamp output from the Blaupunkt deck. But the OEM amp was designed with the OEM deck in mind, so level matching will not be properly set. I've tried this before, and I'd stick with the Blaupunkt's built-in amp instead, and bypass the OEM.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
