Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - ram or cold air intake 93 camry
View Single Post
Old 08-05-2004, 10:54 AM   #8 (permalink)
2wickedtoyz
Mad Scientist
2wickedtoyz's Avatar
Gameroom cash: $249101
View 2wickedtoyz's Photo Gallery
if you treally want to make your own get a pvc pipe the same diameter as the opening. then cut out the part of the air box that it mounts to glue the pipe on the piece you just cut out using epoxy. i use this stuff from versachem plastic welding system. it works great it takes 15minutes to set and is very strong. i got it at advance auto next to all the glues make sure it's off white in color and the container is all black cause the others don't d so well.
[url]http://www.cardomain.com/id/wickedtoyz[url]
Camry Wagon Crew
2wickedtoyz is offline   Reply With Quote
