This connector is different because it doesn't have the typical latch that you depress with your thumb.
The latch has a "u" shaped channel cut into it.
This channel enters a bale and behind the bale is
a oval shaped plastic part and behind that another larger
bale. Looks like it takes a special tool to release the catch. I tried drepressing the oval piece with no luck!
Finally was able to release this connector. Shell is on the main harness side-plug on small harness connected at the tank.
It took a drop light and a mirror to find the tab on the back side of this connector . Then working blind I was about to get the tip of a small screwdriver between the tab and the catch. Separated the the plug using a small pair of pliers:-)
