Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - GReat engine.....maybe?
View Single Post
Old 08-28-2004, 11:48 AM   #8 (permalink)
micro214_kp61
View micro214_kp61's Photo Gallery
Originally posted by Foolish86
ALL 4AG'S HAVE THE SAME BORE AND STROKE. With that said, the AE111 pistons (Black Top 20V) can put on a 4AGZE crank. They also have idenical blocks. I was metioning using the 4AGZE block and crank because it would be cheeper to buy a entire 4AGZE engine, and use the block, crank and supercharger. Then you would have to buy a BLack Top 20V head, which will bolt on the gze block because.....THEY HAVE THE SAME BLOCK! The 4AGZE crank is steel while the rest i believe are cast iron. Anyhow, it would be like running a Black Top 20V with a supercharger and a steel crank.
i'm confused! if the ZEs are a lot common, how is it gonna be cheaper to buy just the BT 20V head (isn't it harder to get this than a AFM ZEs)? i've never seen anyone selling just a head. isn't it better to buy a whole BT 20V, install it and then later on boost it. hachi_slow made a good point, and you're worried about the cranshaft but not with the ohter internal parts which are much lighter (meaning not meant for boosting but for high revs) like the pistons. the AE111 pistons are not really meant for boosting. you'd be lucky if that motor last for a month with even a 5psi of boost and driving it hard. i still don't understand why you have to make the BT boosted, it'll be much much cheaper to build-up the 16V ZEs with much better result. but i you have the cash then goodluck!
toyotaspeed90... i'm still curious about the clearnce issue! thanks..
1982 Toyota Starlet (SP61) boosted since 2007
micro214_kp61 is offline   Reply With Quote
