Originally Posted by Eye8Pussies
so...when are you upping the boost???
Thanks fo rthe comments guys
It has been uped!(I have a boost controller)..im takig it easy for the time being going for 10-12 psi...Im going back to school in september to finsih my eng degree so funds are limited..aiming for 15 psi for this summer.
Car is mad fast! Stock is 225 hp/225 lb t torque at the crank so take off roughly 25 of each for estimated losses. The each extra pound of bost is roughly 11 hp and torque so at 15 should be 270-290ish hp/torque. But I will only go to 15 at night when its cool.
BTW if you are gonna do this swap and cant afford an mr2 lsd tranny....th v6 tranny holds in every gear and spins a bit in first in second if u drive like a retard.
