Yeah so i was gonna start the car and it wouldn't go, then i opened up the hood and realized the head fell off my car... that sucked
yeah - so I found it on the ground
And a bunch of my turbo parts fell off too... should have used a torque wrench
Luckily when the wheel feel off - the car was jacked up for some reason, remember kids to drain your coolant really well because that head will have some extra toyota red pee in it
Anyways - for those of you who take posts to literally - Carl helped me get the head off the camry (it did not just really fall off...) before I sell it or whatever I am going to do with it - I am putting on a thicker cometic HG to drop compression a bit and some ARP studs so that I can feel studly when I drive around... also gonna machine the head incase there is warpage... man I hope a blown headgasket was what was causing the super pressure in my cooling system that caused my old radiator to explode... eh
Oh yeah - speaking of cooling systems, here are a couple crappy shots of the custom radiator Carl fabbed me up - it was a visteon base radiator for a 2G turbo eclipse - he welded on a temperature sensor bung that he made on the lathe, 2 aluminum risers on the bottom to make it sit nice from the ol lathe, and then some bracketo's on top for extra support... Also welded on the moroso gm filler neck with a 19-21psi cap
only drove it about 5 mintues before i was shooting fluid out the radiator pipes because of what we believe to be a blown headgasket (plus white coolant smoke out the exhaust)
give me a week or so - probably a little more since i am moving - should be back together and I will post a nice boosting vid clip to entice people to buy
