Well you seem to start moving @ 3 seconds, and hit 100km/h @ 10.
A 7(+ change) second 0-60mph run is about where you should be. High 14's.
"The lamest twice banned, non-female member of-all time." -Ekam, Thanks, I <3 you too! AIM/Yahoo Toysrme257th
for anything, anytime; including camry turbos Now with Turbo!
You said your 0-60mph time was 6 seconds. It looks to be atleast 7 to me. Not that it matters, good job.
dysk8forlife open it in something you can expand it in. I'm not the biggest quicktime fan, but it does a great job with the 3gp video's. VLC Media player doesn't od a good job synching, and is commong to breka audio, while the k-lite pack is good, but can be buggy paying 3gp's.
To answer everyones comments and reply to them as well...
just want to say that to figure out my 0-60, i use a porgram that brakes a movie clip into smaller frames and milliseconds. Its the most accurate way i found. i used this softwar to see when the needle lifts from 0 and then hits 60mph and it calculated it to be exactly 6 seconds. I did the same to figure out my 0-60 for my k20a swapped civic. Trust me its accurate, and it shows 6 seconds flat. The needle lifts off 0 at 3.6+ seconds and hits 100 mph at 9.6+ seconds if i recall correctly. If anyone has a similar program, you can download the clip then try it for yourself.
The problem with the engine is that its very electronic and thats why it lags. When i'm rolling and then floor it, my revs go up first and then the car moves.
I'll try to make another video, this time more clear and that will start at 0 and end at 6, i think that would help.
The car can hit 220km/h (not sure what that is in mph) but in the video I hit 210 I think because i had to start slowing down.
My spare is a full-sized spare, no tire, weighs ~40lbs and my Volks weigh 16lbs a wheel (w/ tires ~30-35lbs). I removed the full-sized spare and have summer performance tires.
