Slow White at the Streets of Willow, not snow white lol - Page 3 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-01-2007, 03:31 PM   #31 (permalink)
slowamatic noob
a94autoCamry's Avatar
Gameroom cash: $149910
View a94autoCamry's Photo Gallery
^ david, i'm pretty sure my alignment are factory spec...i got an alignment a few months ago but cannot find my printout papers that they gave me when they were done with my car...
btw, i have the TRD rear sway bar already and its on the track setting
Originally Posted by 95WhiteCamry
how many laps are you guys allowed to run on open track days?
its not really how many laps you can do, but they give you like 20-30 mins per session, so as many laps as you can do during that time.
everyone eles, thanks for the comments again...i'm planning to go once again in late september, so Milt...maybe your car will be ready that time
slow white - "no show and no go"
a94autoCamry is offline   Reply With Quote
Old 07-02-2007, 01:38 AM   #32 (permalink)
03 WRX tuned w/Enginuity
View drees76's Photo Gallery
Factory alignments usually give you a bit of toe in and camber will be +- 0.5* in the front and IIRC, the rear isn't adjustable without getting aftermarket camber bolts.
If you can dial in -1.5* of camber in the front, that will really improve front end grip and as long as toe is still set to 0 or just a smidge of toe in, tire wear will still be good.
If you feel like getting more aggressive you get dial in another half a degree or two.
For the rear, if you get some adjustable bolts, -1.0* of camber is a good starting point depending on how the car feels how.
You'll want to get camber within +-0.1* if possible.
How did it handle? Did it push? Did the rear get loose at all? What tire pressures did you run?
Awesome, does TRD make a front bar, too?
drees76 is offline   Reply With Quote
Old 07-03-2007, 02:01 AM   #33 (permalink)
Originally Posted by UfoZ
-1.5 in the front? Shiiiiiiit... That's for amatuers.
Im running -3 front -1.2 rear. 10kg front 12kg rear springs. You want handling... That's the setup. Understeer is nonexistant.
I totally agree with your setup for a super-aggressive setup where you do a lot of racing, but you will get some extra wear on the inside of the fronts with that much neg camber if the car is a daily driver and you aren't constantly slinging the car around corners.
My alignment suggestions are more for the daily driver who occasionally gets a bit aggressive in the corners. Yes, a good setup for amateurs since that's what 99% of us are.
Old 07-03-2007, 09:36 AM   #34 (permalink)
That Acura Guy
TTercel's Avatar
Gameroom cash: $267565
View TTercel's Photo Gallery
Damn man mojor props on racing the Camry
I wish there was a race track close by my house...
TTercel is offline   Reply With Quote
Old 07-09-2007, 03:25 PM   #35 (permalink)
slowamatic noob
it handled pretty well thru the corners with just slight understeer but was controllable... the rear didnt really get loose, and my tire pressure was around 33-34 before running on the track....then it shot up to around 38-39 when hot/running on the track
thanks, glad to represent camrys on the track
(hardcore) ...Toyota Tuning From Birth... arcasmachineracing General Discussion 10 01-30-2003 11:23 AM
Ideal Woman Deep Off Topic 29 08-11-2002 11:05 AM
girlfriends are scary arcasmachineracing Off Topic 21 08-10-2002 04:49 PM
What is this Aug 3rd date I am hearing about? Camry2000 General Discussion 6 07-25-2001 01:53 PM
