Well, I compiled a video of my IS300 before and after turbo... No where near as exciting as my Camry videos, but it will keep us entertained for a few mins....LOL
http://video.google.ca/videoplay?doc...12776&hl=en-CA
Setup on IS300:
Induction/Exhaust
- Garrett GT4088R turbo; 0.95a/r Divided
- Tial 44mm Wastegate
- Modified EBstores Turbo Manifold
- 3.0" Turbo-back Exhaust
- 3.0" Magnaflow Cat
- OEM Supra TT Muffler
- HKS SSQV Blow Off Valve
- Custom 500 HP Intercooler
- Custom Air Accumulator Box (to straighten out airflow for stock MAF)
- VVTi 2JZ-GTE Supra DBW Throttlebody
Engine
- Internally Stock 2JZ-GE
- Stock compression ratio
- 70000 miles on the odo
Fuel System
- Additional 1300cc/min Injectors X 2
- Autometer Fuel Pressure Gauge
- Walbro 255 LPH HP Pump
Ignition
- HKS Twin Power DLI
- MSD Voltage Booster used as Spark Booster
- MKIV Supra TT Individual Coilpacks
- NGK BKR9EIX Plugs Gapped 0.030"
Management/Electronics
- GReddy E-manage Ultimate
- GReddy Boost Sensor
- Dynamotorsports Custom Water/Meth Injection
- Custom Autometer (Subaru STi) Gauge Pod Modified to Fit
- AEM Water Temperature Gauge
- AEM Transmission Temperature Gauge
- AEM UEGO Gauge-type Wideband
- APEXi AVCR Boost Controller
- SplitSecond MAF Voltage Clamp
- Custom Manual Engine Fan Switch
- Custom Self Resetting ECU circuit
Transmission/Drivetrain
- TurboEast Race Transmission
- Amsoil ART Fluid
Handling/Braking
- Tein SS Coilover Suspension
(Front =14.0 kg/mm; Rear = 8.0 kg/mm)
- Powerslot Front and Rear Rotors
- Eibach Anti-Roll Swaybar Kit
- TCSportline Strut Bars
- Hawk HPS Pads
- Yokohama A048 DOT-R Tires
(Front = 225/45-R17; Rear = 225/45-R17)
- 15mm TCSportline Adapter Wheel Spacers
Lighting/Cosmetic
- Type-R Front Lip
- ABS plastic Mesh Paint-matched Front Grill
- Lexus LS430 Projector Retrofit
- Philips D2S Ultinon Capsules
- Zomkspeed LED Tail Lights
- CF Duckbill Trunk Spoiler
Interior/Audio
- Broadway Rearview Mirror
- Full Armrest Conversion
- JL Audio 12W0 Sub with custom spare tire enclosure
- Kenwood Amp with Factory head unit modified RCA connections
