mk3 11's or bust! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-24-2009, 02:07 PM   #1 (permalink)
View supra_villan's Photo Gallery
mk3 11's or bust!
mods thus far-7m, JE's(.20 over) eagle rods, balanced crank, 5-angle valve job w/high temp seals, polished and swirled valves, tms 2mm HG, ARP's, godspeed fmic kit, SSQ, sc61 turbo,custom downpipe, spec pp, act 6-puck disc, fidanza flywheel, PTE 550's/lex afm/afc/lc1 wb, walboro 255lph, aeromotive FPR, 17" Konig's, sumitomo 245's out back, 235's up front, 255/55/16 MT ET streets on mk4 rims for fun fun, Powerslots, ngk plugs n wires, KYBshocks, Eibach Springs, gutted rear, adj. sway bar end links
here is a pic from when i got her, she had a mbc running 10 lbs, apex'i air intake, rims, tires, springs, shocks, and an open tms 3" down pipe, before the big build i put on a few things, ssq bov,upper hardpipes, and a spec clutch
out with the old....
in with the new
here are the parts
precision turbo engineering 550cc injectors
innovate lc1 wideband kit
walboro 255lph fuel pump
aeromotive fuel pressure regulator
Snail! precision 61mm biatches
supra_villan is offline   Reply With Quote
Old 08-24-2009, 02:08 PM   #2 (permalink)
china man t4 manifold w/4-bolt 40mm wastgate flange, i'll be running hks 40mm
all bolted up
full led cockpit!!!
the dash, keyring and glove box lights were supplied by superbrightleds.com, and installed by me. The climate control was done by tsiwithpsi, he is a solder beast! like 20 blue, 20 white and one lonely ass red led's supplied by the chinese!! thanks china! Once my oem parts from tejastoyota in texas(ordered through a guy on on supramania he is an awesome guy to deal with, he got me 20% off!!) get here, which should be next week, i'll finish the engine on the stand, harness and all, and drop that bitch in by the weekend hopefully!!!!!!!!!! but here are pics of the dash and stuff.
gonna keep me comfy
excuse the cell phone pics and dusty ass car
Old 08-24-2009, 02:09 PM   #3 (permalink)
got her on the ground this weekend, changed the lsd fluid too....i don't think it was ever changed in her lifetime, when i had the wheels in the air, i spun one, and the other followed suit instead of spinning the opposite way, so i think it might be shot
here are the leftovers in the drain pan
gettin closer guys........ :evil2:
my ic pipe hits my compressor housing though.....:3d_frown::3d_frown:
put in a 4.30 lsd rear yesterday too, :icon_bigg
lsd is in
oil cooler mounted to the radiator with good ol zip ties through the fins
Old 08-24-2009, 02:11 PM   #4 (permalink)
and where is the coolant reservoir you ask?
:evil2::evil2:
still gotta get my damned turn signals back.... ugh.
Old 08-24-2009, 02:13 PM   #5 (permalink)
on first startup i heard a knocking...so here is the product of the first oil change
well....went to change the oil and inspect the filter...so i drained the old oil....looked a little wierd for 10 or 15 minutes of running time, but i did use some of that oil dye (not more than recommended) so i think that might be the culprit...at least i know its the culprit to the little bright green spots
well.....fuck my life.....found out that this is nothing short of rod knock.....i know this because i got the filter off today....shook it....head some rattling around inside of it. I dump it out to find this....
fucking mud dobbers.....anytime i had an open port in the engine i was sure to stuff either plastic bags, or rags into the gap to make sure nothing got in....guess i was wrong....the shop i had the car in was infested with mud dobbers...i never found any of thier nests in the car, or in the engine bay...i found 3 or 4 on the under carriage of the car....and one in the oil pan from intitial assembly before i had oil in it. I took off the pan, and took a flashlight to where i could see and my hand to everywhere a flashlight would't reach and that was the only one.....so i thought......i'm not sure when i'll get to tear in to this because i don't have 100+$ for bearings....hopefully the crank and rods are fine....i did one last running video just to make sure after i tightened up the crank pulley last night and changed the oil. i'll post that vid here in a minute.....i'm so fed up right now.
Old 08-24-2009, 02:14 PM   #6 (permalink)
I got it all torn apart to find some really nasty oil and some ugly bearings. The oil flickered in the sun like wet metallic paint. The crank weights had some heat marks on them you can see that in the pics. The rods and rod journals looked fine with no deep appearing scratches or none that i could feel with my fingernail. The filter i removed was only ran for 2 or so minutes with it knocking and thank god there were no solids hanging out in there unlike the old one. Although i did dump out the filter and after it spilled all the oil inside of itself it was still pretty heavy not sure if thats normal on a wix. I didn't take the main caps off because i was losing daylight and i was curious if there was a way to get to the motor(top) side of the main bearings without removing the flywheel and stuff. Can i get away with not replacing the mains? I'm not sure i figured i would ask the community for there input because i always get some good ideas from you guys. Do you guys think a set of std clevites would suffice as long as i do this by the tsrm with a quality snap on torqe wrench and some plastigauge i have access to a mic also.
And is there any way to get all the old oil out without pulling the motor?
#1
#2
#3
#4
#5
#6
Old 08-24-2009, 02:14 PM   #7 (permalink)
Here is a vid of it before the teardown. Excuse the nasty cluttered engine bay i plan to sort that out once i get it running right. Also excuse the shitty running i think my relocated coils have a shitty ground. Tell me what you guys think.
Old 08-26-2009, 03:36 AM   #8 (permalink)
slowamatic noob
a94autoCamry's Avatar
Gameroom cash: $149910
View a94autoCamry's Photo Gallery
very nice mk3, keep up the good works!!
slow white - "no show and no go"
a94autoCamry is offline   Reply With Quote
