My other headache - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-28-2009, 12:49 AM   #1 (permalink)
correction: I hate Isuzus
InfInIty13X's Avatar
View InfInIty13X's Photo Gallery
XXX My other headache
I thought I would start a thread about my other car. It was a 1993 Geo Storm GSi with a 1.8L motor that produced 140hp/120lb. I purchased it in 2004.
It was quite zippy but as I read more about it on the internet I came across it's sister car: the Isuzu Impulse. Specifically I was interested in the 1991 Impulse RS model because it is a 1.6L turbocharged motor producing 160hp/150lb. It is almost a direct swap but as I had a 1.8 there would be more customizing than if I were swapping it from the lesser 1.6L n/a motor available in the base model.
After reading about this project for a while I decided to start off with some coil-overs. They provide a 3" drop in the front and a 4" drop in the rear. I dropped them all the way. The spring rates are 450lbs. for the front, and 350lbs. the rear.
This picture should give you an idea of the drop when you compare to the Camry.
Well the handling was amazing with the coil-overs so I really hot dogged it. I ended up doing this shifting into fourth at about 100-110mph. I was trying to keep up with a Trans-Am. That was the #1 rod bearing. The rod was burned black along with the crankshaft counterweights. The rod bearing cap is crap now. Oh I forgot to mention how the bearing sheared and worked it's way up the rod where it is now stuck. To be fair the bearing had been knocking a few months prior to this incident.
(from here the pictures get fairly large so I will just direct link to them)
Luckily I had just purchased an '85 Supra to get me around so I found an Impulse engine in a junkyard in New Castle, PA and had it shipped here to Alabama. I decided it would be best to tear it apart and rebuild it. I was glad I did because the valves were rusted and the crank journals were seriously scored. Here is the head torn down and the empty block.
Years go by as I sit lazy and slowly collect turbo parts. Last year I finally got around to getting my headwork done. (A,B,C) I installed the 1.8 cams and lifters because the 1.8 uses hydraulic lifters and the 1.8 cam profiles are a little more aggressive than the turbo cams. I had to swap oil control valves and cam gears in order to do this.
Shortly afterward I had the block cleaned (sort of) so I could put the guts back inside. The main journal bearings for some reason don't really come with oil squirter holes pre-drilled so I had to drill my Toga bearings. Here you can see the oil squirters built into the block for the rods. It is in the center of the bearing. Now I was able to install my good and new crankshaft and pistons. After four years I finally have my motor looking like a real motor. I swapped the intake over from the 1.8 because it has four big runners instead of many small ones and I removed the butterfly valves. You can also see my underdrive pulley I installed in place of my crankshaft pulley. The weight difference is crazy.
I had to go to a local race shop and get them to make my custom turbo oil feed. Here are a few pics of it installed. (A,B,C)
That brings us to today and what I accomplished. I had to make some custom radiator hose since it is a 1.6 engine and I'm still using a 1.8 radiator. Here ya go! (A,B,C,D,E)
'96 Geo Prizm base 280k+ miles
'91 Isuzu Impulse RS 130k+ miles (parked with bhg)
InfInIty13X is offline   Reply With Quote
Old 08-29-2009, 01:02 AM   #2 (permalink)
Every road's a playground
toyotaholic's Avatar
View toyotaholic's Photo Gallery
Quite a project you got there. Is the CRX yours too?
toyotaholic is offline   Reply With Quote
Old 08-29-2009, 03:51 PM   #3 (permalink)
No but my buddy who did own it dropped a ZC(?) engine into it. He had it gutted and straight piped so it was fairly quick. Quicker than the Storm. That car is history now though.
Old 08-31-2009, 12:46 AM   #4 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
Cool project. At the dyno shop, we had a Impulse put a little over 300whp on the dyno... Inspiration much? Stock bottom end too...
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 08-31-2009, 08:32 AM   #5 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
Wow dats a nice lil' project. No something you see much of.
http://www.xclusive.bz
Old 09-03-2009, 01:24 AM   #6 (permalink)
The stock internals can handle up to ~400 hp before serious modifications are required and at that point you're really looking at a rod/piston upgrade.
The Florida boys are some of the most active and serious tuners in the community. The others are located all along the west coast.
Old 09-04-2009, 12:03 AM   #7 (permalink)
This is what I got done today. The pictures are pretty self explanatory.
VVV This hose is touching the CAS. Should I space it away or will it be fine? Note the wires below the CAS also touching the hose. VVV
VVV I just capped off these two ports because well it was just easier this way instead of having to T into more line and yada yada yada. VVV
VVV My Prestone coolant back-flush T fitting. I just happened to have this lying around. I ran the heater return hose to the coolant dump pipe for the block. The T fitting let me join the two hoses. VVV
Some of the ignition module wiring I already lengthened.
These wires I didn't mess with yet because it looks to be a 14 gauge wire instead of 16 which the other wires are. I don't want to put 16 gauge into a 14 gauge wire. BTW this wire is rated for 15A. Is that going to be a problem?
My capped off oil bypass port on the back of the block.
