hey everyone. My name is kevin, and this is my swap. I figured it was about time there was some sort of update. The engine now has the front sump on it so i could bolt the engine in and see how everything fits. All the electronics are torn off for matts obd2-obd1 conversion on his supra since i will be going stand alone. the internals looked good, to me at least.the car is gutted so matt can stitch weld the seems.we've dropped the rear subframe in favor of using the mk3 turbo rear subframe, beefier and i get 5 lug
But! pictures are better than words.i'll try to explain with the pics what is going on.
Removing the sound deadening:
Pulled mk2 subframe for mk3
had to cut the front outer bushings off to make it fit under the car
and just seeing where it ends up
when i walk out to the garage, this is what i see
and a little teaser
so, that's it in a nutshell for now. matt and i work on it almost every weekend now.been loads of fun.i couldn't have gotten here without him and my other friends that help me when they can.
