Yeah here a pic of the idiot ... That got wouldnt let my homie Shelby pass ... Shelby was on his ass all thru out the corners and when they get to the striaght away the 510 with an sr20 would just pull away ... Not right at all
before :
after :
If your on the track and you do that to me ... I would pressure you to death or dive bomb you in every corner... The guy got what he deserved...
=engine mods=
-E.L. Prototypes Cold Air Intake
-E.L. Prototypes Header
-Spec Stage 2 Clutch with Kevlar segmented disc
-Tom's 7.8lb Lighten flywheel
-Perrin Lightened Pulley
-Apex'i S-AFCII
-200cc 1999 Corolla 1zz-fe injectors
-Apex'i EL1 Tach
-2.5" E.S Tunning Muffler
-2.5" exhaust from cat back
-2.5" in/out AE111 20valve resonator
-4" Sebring tip
-Custom blue grounding kit
-Hawker Odyssey 15lb battery PC680
-upgarded head light wiring harness
-5zigen oil cap
-TRD radiator cap
=suspension mods=
-Tein Super Streets that was re-valved and re-stroke ( 83mm of stroke in the front and 140mm stroke in the back)
-Swift Springs 7kg in the front and 8kg in the back
-Cusco Camber plates
-Cusco mid frame brace
-JIC front suspension bar
-DC SPort strut bar
-TRD rear frame brace
-Ebay copy of a Do-Luck center floor brace
-White rear sway bar
-Upgraded Prothane sway bar bushings
-PBR brake pads
-Custom Stainless steel brake lines
=interior=
-SCion XA Driver and passenger seats
-Momo shift boot
-TRD shift ball
-Tom's steering wheel
-Tom's horn button
-TRP 75mm Hub extender
-Nardi Boss hub
-Nardi steering wheel spacer
-Razo pedals
-Crow enterprise harness bolts
-Sparco EVO L ( EVO II new edition) complete with sliders and custom rails
-Custom Pass Performance Harness bar
-5 point Crow Enterprise harness
-Vitz Arm Rest
=extrior=
-Raybrig wireless remote yellow fog lights
-Narva Gold all weather bulbs
-14x7 Panasports (ProRally model which is for Racing Purpose only)
-205/60-14 Toyo Proxes RA1 road racing tires
-Tundra wheel studs
=Fluids=
-Motul 300V 5w40 for the tracking
-Motul 8100 Xcess 5w40 for the streets
-Motul Gear 300 for the trans
-Motul Inuegel Optimal Ultra for the radaitor
-Motul RBF 600 brake fluid
Waiting for it to arrive in the mail:
-New 15x8 Work Equip 03's
