Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Turbo charging 4AF
View Single Post
Old 09-24-2004, 04:00 PM   #5 (permalink)
Flashmn
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
pressure box is a box built around the car, that equilizes the pressure around the carb so that the throttle shaft wont leak out pressure and that the float chamber get the same pressure.
If you dont pressurize the carbs, it wont work, fuel will just back out and leak out from the float chamber.
I'd say 5psi can be done, I'd keep the limit at 8 or 9psi with the stock parts.
