yap, it's a camry gen5. sorry, i thought that this was the camry section....my bad.
what is happening is when i close the sunroof, it closes "too" much. the front end is fine, but the backend seems lower than the front...so there's a gap in the back....toward the trunk.
i tried what you suggested but am having issues with this part
Within 5 seconds press and hold the close button untill the sunroof closes itself, then the sunroof will completely open itself, then it will completely close itself, once the sunroof is completely closed you are done. make sure you are holding teh closed position the entire time of this step. Sometimes it takes 30 seconds or so for the sunroof to respond and start moveing
i hold the close button to close it and hold it down, but the roof doesn't react besides just closing it...it doesn't open back up like it would if i hit the button again.
am i don't this correctly?
thanks all for the help.
