fuel filter - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 10-06-2005, 08:43 AM   #1 (permalink)
View n2000snake's Photo Gallery
fuel filter
Ok fellas I'm a newbie on here, I'm just doing a post for my friend,, He doesn't know how to use a forum.. I'm usually on the audiworld forum...
Well anyway He has a 2000 solara V4,, he needs to change the fuel filter! where is it located? how much? and how hard is it to change on my own?
thanks again
neil
n2000snake is offline   Reply With Quote
Old 10-06-2005, 08:30 PM   #2 (permalink)
View deekay140's Photo Gallery
should be under the airbox
deekay140 is offline   Reply With Quote
Old 10-07-2005, 08:13 AM   #3 (permalink)
thanks
thanks bro
Old 10-07-2005, 03:57 PM   #4 (permalink)
The Other White Meat
terrastrife's Avatar
fully sik motorbike engine bro
ya have an inline 4, not V
terrastrife is offline   Reply With Quote
Old 02-17-2006, 12:32 AM   #5 (permalink)
View marc780's Photo Gallery
Im not sure if this applies to your year, BUT there is an odd, U shaped metal cover over the top connection. You gotta pop that off first by squeezing and pulling at the same time.
Then the fuel line connection is held on by a little plastic thimble-shaped clip. Hopefully your new filter comes with new clips.
The clip can be tricky to pop off unless you have fingers like michale jackson or ET so it may be easier remove the air filter box first. Have some good light for sure. i popped mine off by using a very small slot screwdriver or needlenose and and push in through the square slot at the same time. Hard to explain but youll understanad when you see it. Then the fuel line just pops out Watch out for squirting fuel1
