2000 solara 02 wiring need to know what colors go to what - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 10-11-2005, 09:02 PM   #1 (permalink)
imtweakinit's Avatar
View imtweakinit's Photo Gallery
my o2 sensor has 2 whites a black and a gray but my car has a white a blue and i forgot the colors could someone look on their car and let me know what goes to what please
imtweakinit is offline   Reply With Quote
Old 10-12-2005, 08:22 PM   #2 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $282392
View csaxon's Photo Gallery
http://www.automedicsupply.com/pictu...tructions5.jpg
4 or 6 cylinder?
It worked fine until I fixed it!
csaxon is online now   Reply With Quote
Old 10-12-2005, 10:27 PM   #3 (permalink)
six cylinder
Old 10-13-2005, 01:01 PM   #4 (permalink)
Make sure you have the right sensor!
If your saying that the wires from the car are blue(signal wire), white (ground) , (2)black(heater). Then that's a type B system.
Your replacement a black(signal wire), gray (ground wire), and 2 white (heater wires).
That's a type d system. It may work but I'd double check that you have the right part. It doesn't sound like it.
Old 10-13-2005, 07:35 PM   #5 (permalink)
i did check and those are the colors and are also the same colors on the one i took out but when i spliced them together i lost track to where the went meaning what color went where would you know so i can hook it up right or the right diagram i dont think the one you sent me is right
i bought the sensor from auto zone and they said it was the right one also colors on sensor matched the old sensor car still runs normal but the stupid engine light wont shut off so i think it hooked up wrong
Old 10-13-2005, 10:00 PM   #6 (permalink)
I'm sorry but you've confused me. Your post says "my o2 sensor has 2 whites a black and a gray but my car has a white a blue and i forgot the colors"
Now you say "those are the colors and are also the same colors on the one i took out"? Which is it? black white gray or blue white black?
Go back to autozone and have them check the error code (it may be a new problem) and see if they can reset it.
If they can't then disconnect the negative battery cable for about 90 seconds to clear the code. Reconnect the battery cable and see if the light returns.
What brand did you buy? They may be able to help you there with an installation instruction sheet. Do you remember the original Diagnostic Trouble Code?
Old 10-13-2005, 10:27 PM   #7 (permalink)
I'll take a stab at what I think your situation is. If original is 1 blue then splice to the new 1 black. Original 1 white, splice to new 1 gray. Original 2 black, splice to new 2 white.
Look at the img I sent.
The Toyota 4-wire. Top left is OE (original equipment) it shows BLUE. The universal replacement you mention to splice into BLUE is Type A BLACK. Notice that the type b replacement is a perfect color match.
http://www.automedicsupply.com/pict...structions5.jpg
Good luck.
Old 10-14-2005, 06:57 AM   #8 (permalink)
hi the diagram you sent didnt work and imtrying to wire the factory plug in to the o2 which on the car side not the o2 side has the blue wire
Old 10-14-2005, 07:30 AM   #9 (permalink)
Ferocious Teddy Bear
WortownSolara's Avatar
View WortownSolara's Photo Gallery
wow i cant get away from my car no matter what i do
If it doesn't kill you, it only makes you faster!
WortownSolara is offline   Reply With Quote
Old 10-14-2005, 07:53 AM   #10 (permalink)
i hope this is for the rear o2 sensor, because no matter what you do, your still gonna get a CEL. THERE IS NO CAT ON THE CAR DUDE.
Old 10-14-2005, 07:33 PM   #11 (permalink)
hey whats up but it actually the front one bank 1 sensor 1 and me and the car could use all the info that you can give me imgoing to go to is it xtc to see what up oh ya why did you get rid of the car we really need to talk ill buy you lunch or something just to get the low down on the car
Old 10-14-2005, 07:42 PM   #12 (permalink)
and im sorry wortown but you will be seeing and hearing alot about the car cause i want to learn and do all i can to make it better and faster and could really use your help doing it at least you know that it went to someone who is going to take care of it and make advances to it
Old 10-14-2005, 09:30 PM   #13 (permalink)
Good luck guys. I hope it works out between you.
Old 10-15-2005, 11:13 PM   #14 (permalink)
Offical TN Vendor
View Gadget@URD's Photo Gallery
What are you trying to do or install??
Gadget
www.GadgetOnline.com
Gadget@URD is offline   Reply With Quote
