Passenger Headlight Out - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 10-13-2005, 04:17 AM   #1 (permalink)
Yep.
thealkimo's Avatar
View thealkimo's Photo Gallery
recently my passenger hid went out and i found that one of the cables was rubbing against something hot and seared the cable down to a point where it can no longer hold electrical current...
and now i have removed the bulb and ballast to send back to have it replaced and threw in a stock halogen bulb and now that light doesn't turn on at all...
i checked the plug and its fine and then i checked the fuse and it appeared to be just fine...anyone know what is going on with this???
My Cardomain
thealkimo is offline   Reply With Quote
Old 10-17-2005, 04:04 AM   #2 (permalink)
Yep.
thealkimo's Avatar
anyone know how much is involved to replace the electrical harness for a headlight?
My Cardomain
Old 10-18-2005, 03:04 PM   #3 (permalink)
View 05v6solara's Photo Gallery
Good news and Bad news!
Good news: if the cable is damaged in only a short section i.e. 2" or so you can cut that piece out, solder a new piece on and put heat shrink tubing to weather proof it.
Bad news: if you choose to go with a new harness, you will pay well over $100-150 as a guesstimate.
Sig removed. Violation of rule #4.
http://www.toyotanation.com/forum/t20118.html
05v6solara is offline   Reply With Quote
Old 11-05-2005, 11:52 AM   #4 (permalink)
TACO FTW
Location: Norton Shores, MI / Houghton, Michigan (MTU) FTMFW
View 92_Gen3_5SFE_LE's Photo Gallery
well if it rubbed throught the cable to the point here it wouldnt hold current it probably blew a fuse or shorted somthing out
92_Gen3_5SFE_LE is offline   Reply With Quote
