buiding engine - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 10-19-2005, 09:20 PM   #1 (permalink)
imtweakinit's Avatar
View imtweakinit's Photo Gallery
buiding engine
i want to build a engine where can i go online to order parts for a 2000 solara v6 3.0l will be running s/c with 6 lb pulley
imtweakinit is offline   Reply With Quote
Old 10-20-2005, 05:25 AM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
everythigns going to be custom so ya better off looking for a local workshop and working with them to get what you want.
if youre an engine builder then you would have your sources already.
terrastrife is offline   Reply With Quote
Old 10-20-2005, 07:52 PM   #3 (permalink)
never built a toyota engine built 5.0s and thats what everyone does in my area the only place around me is autozone which sucks
Old 10-21-2005, 07:41 AM   #4 (permalink)
RedKnight
View JoeB's Photo Gallery
hmmmm, that's scary. I see why you've asked in many different threads on different boards about engine kits. If you are used to Ford's 5.0, you are coming from a different world. There are many engine building kits and readily available parts for that engine. There is nothing available for the 1MZ-FE. As I posted on SolaraGuy, everything will be custom and/or from other applications and VERY expensive. I don't know anyone that considers AutoZone an engine builder. -JoeB
Please stop by and rate my ride:
http://www.cardomain.com/id/jbailer
JoeB is offline   Reply With Quote
Old 10-21-2005, 10:30 PM   #5 (permalink)
not to build engines just for parts meaning autozone. just wondering if i was to buy a rebuilt engine would that be smarter than buiding one i have like $2000 to play with do ya think i might be able to do a mild build with that much not going crazy like your car but able to handle 6lbs safely i have bigger injectors ,fuel mod s/c,exaust, and i run 93 with octane booster added. thats the best i can do with running high octane
Old 10-22-2005, 08:36 AM   #6 (permalink)
RedKnight
It's hard to do anything in the engine for $2k. Parts alone will run at least that much. Machine work is pretty expensive too. Unless you will be doing all the labor, I just don't see how it would be possible. A rebuilt engine isn't going to help you any unless they used forged pistons on the rebuild. Sorry, I know this isn't much help but my advice would be save that $2k. If you don't have an A/F piggy-back and a good tune, the way you are pushing it, you will soon need that money and more. -JoeB
Old 10-22-2005, 04:50 PM   #7 (permalink)
i just ordered the apexi safc2 so that should help out ? how do i tune it in do i drive the car or does it have to go on the dyno ill have it in 3 days so i could use all the info on how to use it and also yes the rebuid comes with forged pistons
Old 10-22-2005, 08:31 PM   #8 (permalink)
RedKnight
If you can buy a rebuilt engine with stock compression and forged pistons for a good price, that's probably your best bet if you plan to stick with 6psi. With that setup, I would feel comfortable going to 7psi. Even 8psi with a better management system that could pull some timing.
As far as installing the SAFC2, there are some install/setup guides around. You should be able to find them with a little searching. I forget where they are posted. If you have any questions on the settings, post them and there are many of us with them installed that can tell you.
As for tuning it, you'll need an OBD2 scanner to tune the closed loop and a WBO2 sensor/gauge to tune the open loop or take it to a dyno for tuning the open loop. Don't assume they will tune the closed loop for you though, I've never seen a dyno shop do that. -JoeB
Old 10-23-2005, 02:24 AM   #9 (permalink)
you probably want forged rods/pins as well... 1mzfe rods are piss poor,theyll probably break b4 you start to melt the stock pistons.
Old 10-23-2005, 07:37 AM   #10 (permalink)
RedKnight
Actually, the rods aren't really all that bad. I'd personally never push them past about 350-400 to the wheels but they can certainly safely take 7-8psi. I would consider replacing the rod bolts though with some good quality ones from ARP. The rods definitely will take much more than the pistons. -JoeB
Old 10-25-2005, 05:05 PM   #11 (permalink)
thanks guys
