Check Engine Light Help - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 10-24-2005, 04:40 PM   #1 (permalink)
View 2001SOLARABABY's Photo Gallery
Hey guys I need to know where i can get a cheap scanner to find out how to get rid of my bloody check engine light its gettin on my nerves.
I mean the car seems to run fine but i dont wana kill it cuz i didn't scan it.
Can anyone let me know where i can get one of these scanners,, and also if i disconnect the battery to try and clear it will that mess up my programmed keys/remotes or anything?
I am completely new to jap cars so i am in the dark completely when it comes to maintenace
Please let me know from some of your wisdom .
2001SOLARABABY is offline   Reply With Quote
Old 10-24-2005, 10:32 PM   #2 (permalink)
View bassthrive's Photo Gallery
parts stores like autozone, discount/advance auto parts, pep boys.
most of them have obdII scanners that can read and clear the code for you, for free!
now with 100% more clickability
bassthrive is offline   Reply With Quote
Old 10-25-2005, 12:21 AM   #3 (permalink)
View Calvin327's Photo Gallery
First of all what was the last thing you did to the car? Second check all the fluids, oil, tranny, coolant, etc. Next if the car seems fine and normal, reset the ecu manually by disconnecting the negative terminal on the battery (the right side one) for 10 minutes and put it back on. The check engine light should be gone by then, if not you have some other problem. Its common that the fluids might be low to throw a check engine light, especially the Transmission fluid.
Good Luck
Calvin
Calvin327 is offline   Reply With Quote
Old 10-25-2005, 07:56 AM   #4 (permalink)
I havent done anything with the car yet, as far as MODS or anything have had it for a month and the light just came on last week, it seemms to drive fine, and it is manual so it cant be tranny fluid..
I will disconnect the battery and see what happens
thanks guys , I'll keep u posted.
Old 10-25-2005, 12:27 PM   #5 (permalink)
Also make sure the gas cap is on tight.
Old 10-26-2005, 09:32 AM   #6 (permalink)
Ferocious Teddy Bear
WortownSolara's Avatar
View WortownSolara's Photo Gallery
there are plenty of OBD2 scanners that you can buy off of the internet for $50 Us or so. I would have the vehicle scanned rather than just disconnecting the battery.
If it doesn't kill you, it only makes you faster!
WortownSolara is offline   Reply With Quote
Old 10-26-2005, 01:06 PM   #7 (permalink)
I Disconnected the batt and the light is now off,, when i was disconnecting the battery i decided to check the air filter and it was nasty,, i vacumed it out for now and the whole housing had wasps and crap in it, vacumed that,,
Could that have caused the check engine light??
As far as these OBD scanners do i need software to use it on my Solara,, and can i use it on my GF's Acura 1.7 EL??
Old 10-26-2005, 01:22 PM   #8 (permalink)
View jmd445's Photo Gallery
Scanner
No, you can but a cheap scanner that will provide your engine codes or as stated earlier go to pep boys, autozone, etc and they will usually scan for free and clear the light so they can sell parts.
jmd445 is offline   Reply With Quote
Old 11-21-2005, 10:06 PM   #9 (permalink)
MDT Toyota Tech
View BadChicken's Photo Gallery
It'll probably end up being a P0171 code.
BadChicken is offline   Reply With Quote
