like phi said, to remove the black trim, pull it starting at the bottom (removing ashtray lets you get a good grip). There are 4 clips holding it in. You will also need to disconnect a few plugs from the back of the trim - clock, hazard, ashtray, cig lighter, Stock headunit held in with 4 bolts. Walmart has the scosche harness you need for cheap. If you have JBL, you will not re-use the wires you disconnect from the stock h/u. Instead, reach in and to the right of the radio and hook your harness into those two white standard toyota radio plugs.
now with 100% more clickability
