HELP: Subwoofer Replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 11-05-2005, 02:33 PM   #1 (permalink)
View richardls's Photo Gallery
Question HELP: Subwoofer Replacement
The factory subwoofer on my wife's '02 solara convt is shot. I'd like to replace it. Can someone provide me specs and install instructions. I tried to access it from the trunk, but realized I'll need to get behind the rear seatback to remove it. Thus, I guess it's really more instructions on removing the rear bench (or seat back if it's two parts).
Thank you in advance for your responses.
-Richard
richardls is offline   Reply With Quote
Old 11-05-2005, 04:20 PM   #2 (permalink)
Phreakdout's Avatar
View Phreakdout's Photo Gallery
It should be two pieces. The bottom seat comes out first then the back is probably bolted down. This photo is from one of our SG members.It should give you an idea of what you're looking at.
Phreakdout is offline   Reply With Quote
Old 11-07-2005, 02:13 PM   #3 (permalink)
Thank you for this reply and picture, but I know her back seat doesn't have head-rests, so I'm not sure if this will be helpful. Also, where are the bolts to remove the bench and how large is the woofer?
Old 11-07-2005, 02:54 PM   #4 (permalink)
Ferocious Teddy Bear
WortownSolara's Avatar
View WortownSolara's Photo Gallery
i would not try and buy an aftermarket replacement. The amplifier has a built in EQ tuned for that subwoofer. Most aftermarket subwoofers are too power hungry to operate of the limited power that the factory system has.
If it doesn't kill you, it only makes you faster!
WortownSolara is offline   Reply With Quote
Old 11-07-2005, 03:52 PM   #5 (permalink)
Thanks for your feedback. My wife actually found it to bassy with the sub and doesn't want to spend the $ to replace it. She wants me to just remove it. I thought it should be replaced. What would you suggest given your concerns now that it's blown?
Old 11-08-2005, 08:35 AM   #6 (permalink)
volvoex
View volvoex's Photo Gallery
USA
I've got an '02 convert also and the subwoofer drives me crazy. When it blows it'll stay that way. The JBL system in this car is the only disappointment in an otherwise super vehicle. The menu-type adjustments for bass, treble, etc. are hard to use. too much fiddling to get a decent sound. Had the same setup in my '01 Celica. Hey I'll live with it to have a dependable and comfortable ride.
volvoex is offline   Reply With Quote
Old 11-09-2005, 09:34 AM   #7 (permalink)
My first thought here is to actually dissconnect the sub. Ask your wife to listen to the system without the sub. MOST IMPORTANTLY!!! See what volume she is playing it at when there is no sub connected. The reason i say this is that, humans in general will subconsciously tuen the volume up to get greater depth in music (depth being sub frequencies). If she is happy with the sound she is getting, and NOT playing the system at an abnormal volume. I would just leave it disconnected.
If she is not happy. I can do some digging, and im sure i can send you in the right direction to get the sub to be 3 or 6db's lower than what it is set for (FYI: every 3db loss is half the percieved volume)
Let me know what i can do for you.
GOOD LUCK!!!
Marc
Old 11-09-2005, 07:02 PM   #8 (permalink)
View skadoo323's Photo Gallery
wow i didnt know they had an option for a sub from factory. do you have the JBL system or do you guys have some other head unit?
skadoo323 is offline   Reply With Quote
Old 11-10-2005, 09:20 AM   #9 (permalink)
it is a fujitsu radio with a JBL passive crossover board in place. For those of you who dont know Fujitsu is the company that makes Eclipse. Now dont expect the OEM versions to have the same clarity as an aftermarket eclipse. But at least you know where its coming from.
Old 12-29-2006, 10:55 AM   #10 (permalink)
PDM
View PDM's Photo Gallery
European Union Sub-Woofer problems
Hey Guys, this is interesting. I was going to post a question on the forum, but this thread seems to be 'right on the money' for our problem. My wife has a Solara but hates the sub-woofer sound. I was going to try to disconnect it but am not sure how to go about this? Also, I noticed one of the replies on this thread discusses a possibility of reducing the dB level of the sub-woofer... how do you do this? I have tried reducing the bass on the stereo head unit but to no avail. Any help and/or advice would be appreciated. Thanks in advance.
PDM is offline   Reply With Quote
Old 12-29-2006, 06:23 PM   #11 (permalink)
Every road's a playground
toyotaholic's Avatar
View toyotaholic's Photo Gallery
^ why dont you just turn the bass level ot zero
toyotaholic is offline   Reply With Quote
Old 12-31-2006, 01:40 PM   #12 (permalink)
PDM
The first thing I tried was turning the bass to zero, I even tried 'upping' the treble and mid tones to max (+5). The sub-woofer is still filling the car with bass sound. Any other suggestions?
