new solara problems - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 11-27-2005, 08:10 PM   #1 (permalink)
View zeppman's Photo Gallery
new solara problems
Hey guys,
I'm new to the forum here, but after several problems with my '05 solara, I got on the web searching for answers. I have had 3 problems that I can't exactly overlook.
The first being that I just discovered the driver's side window leaks by the side view mirror. In comparing the rubber weather stripping that lines the bottom outside of the window (top of the door) you can see a rather large gap on the drivers side that is letting water in and is leaking below piece of plastic opposite the mirror on the inside of the door. Why didn't Toyota's quality control catch this? Anyone else have this problem?
The second problem is that the right rear shock makes a loud thudding noise no matter what kind of bump I hit in the road, large or small. I see that other Toyota solara owners have this problem too... how do I fix this? The dealer claims he couldn't find anything...but other owners say it is a "bump stop"?
The third is that if feels like the alignment is off. I have to have the wheel turned slightly to the left to keep the car straight. The dealrship blames it on the tilt of the road...but it can't be that much of a tilt! Any suggestions on this?
I'm going to be taking it to the dealer on Tuesday, but until then, I wanted everyone elses opinions...thanks!
zeppman is offline   Reply With Quote
Old 11-28-2005, 09:41 AM   #2 (permalink)
Ferocious Teddy Bear
WortownSolara's Avatar
View WortownSolara's Photo Gallery
weall of your problems seem pretty conclusive. The Window NEEDS to be realigned. The Shock should DEFINATLY be looked at again. Dont take any BS from the dealer. IF you have a concern that they says is normal. Ask one of them to go for a ride with you. And it doesnt cost them that much to do an alignment. FORCE THE ISSUE. Remember, they are SERVICE. and sometimes you need to point that out. You are the customer and you have concerns.
If it doesn't kill you, it only makes you faster!
WortownSolara is offline   Reply With Quote
Old 11-28-2005, 02:32 PM   #3 (permalink)
What the Pho?
View SolaraTRD's Photo Gallery
Definatly an 05 shouldn't have a thumping noise, nor a leak. The alignment they might tell you to pay for.
Should be under warrenty for the faulty parts. GL
~TN.com Unofficial AIM list~ Updated: 2-23-08
SolaraTRD is offline   Reply With Quote
Old 11-29-2005, 08:48 AM   #4 (permalink)
Well I dropped it off at the dealer today, we'll see what happens. Thanks for the advice guys, I'll let you know how it turns out.
Old 11-29-2005, 11:32 AM   #5 (permalink)
View 06Toyo Chick's Photo Gallery
hey hope everything turns out ok~ I have the 06, no major problems-- thank god~ But all those problems you just noted should be covered under the warranty.
06Toyo Chick is offline   Reply With Quote
Old 12-15-2005, 10:42 PM   #6 (permalink)
View scubasteve's Photo Gallery
I got my solara reciently and everything seems fine.
For the first week my wheel was a little tilted, but was fine after the first week.
scubasteve is offline   Reply With Quote
