solara headlights - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 01-14-2006, 12:30 AM   #1 (permalink)
View itzcam's Photo Gallery
solara headlights
i was wounderin is there any way i can keep my headlights off witout turnin them on..cuz once i put my car in gear tha headlights come on..that sucks..i got tha 99-01 ..cuz i was g0nna get hids and if they keep runin..thats g0ne kill my bulb life..
itzcam is offline   Reply With Quote
Old 01-14-2006, 09:42 AM   #2 (permalink)
Ferocious Teddy Bear
WortownSolara's Avatar
View WortownSolara's Photo Gallery
yes you can! Day time running lights are easily defeatable. To get TOTAL control of your headlights, do 2 things.
1. Under the hood, passenger side, right next to the fire wall, you will see a grey, 2-wire plug. This needs to be dissconnected.
2. You notice on the pasenger side dash there is a redish globe. Remove the glove box and push that up. Disconnect the 2-wire plug attatched to it.
DONE you now have 100% control of your headlights
HAVE FUN!
If it doesn't kill you, it only makes you faster!
WortownSolara is offline   Reply With Quote
Old 01-14-2006, 02:50 PM   #3 (permalink)
wow thanx alot..alot of help..
Old 01-17-2006, 04:26 PM   #4 (permalink)
Wstsydthug
View Wstsydthug's Photo Gallery
Glove Box Removal
How hard is it to remove the glove box?
Wstsydthug is offline   Reply With Quote
Old 01-17-2006, 06:00 PM   #5 (permalink)
its actually very simple. Remove the kick panel. there will be three screws along the bottom of the glove compartment. open the door to the glove and there are 2 more screws.
Old 01-24-2006, 03:15 PM   #6 (permalink)
View lilm's Photo Gallery
you actually dont have to remove the glovebox
just get a flathead screwdriver put a little tape on the tip so you dont scratch anyting and pull the likke globe ting up....disconnect and tie the two pices together with a peice of string or zip tie.....in all takes maybe 13 secs
lilm is offline   Reply With Quote
Old 01-25-2006, 12:08 AM   #7 (permalink)
Stock Sleeper
1st Gen Sol's Avatar
Gameroom cash: $107505
iTrader Score: 7 reviews
View 1st Gen Sol's Photo Gallery
Just unplug the sensor inside the engine bay on the passenger side. This will disable the day running lights.
If you want them fully disabled, also pop out the globe sensor on the dashboard on the passenger side and disconnect that plug also.....then you'll have full control of when your headlights are on & off.
1st Gen Sol is offline   Reply With Quote
Old 01-26-2006, 10:34 AM   #8 (permalink)
Wstsydthug
So what happens then when you just unplug the sensor in the engine bay? Does this mean that there are no day running lights but that they still do come on automatically when its not light out? Or do you have to control them manually 100%?
Old 01-27-2006, 01:35 AM   #9 (permalink)
Stock Sleeper
^^^^ Thats correct. If you only disconnect the gray plug in the engine bay the DRLs will not come on until nightfall. I have mine set like that and haven't had a problem.
History of the Toyota Solara Ratko Solara 17 05-28-2011 08:49 PM
99 - 00 Solara Headlights 1st Gen Sol Solara 0 12-02-2005 02:50 PM
Solara Projector Headlights?????? SatHothi Solara 5 06-11-2005 02:19 PM
99-01 Solara projector headlights???????? envycycles Solara 3 11-10-2004 11:03 PM
My Solara Headlights are dutty INTERNALLY SolaraTRD Solara 4 04-22-2004 01:54 PM
