Originally Posted by glicorish
I had my check engin light on and shortly after my traction light came on. Pull codes and they show a multiple of things. I disconnected the batter. Using repair manual and mulitmeter I went through each code. I replaced the rear O2 sensor reconnected the battery and all is well. NOTE follow each code all the way through ... it could be other problems that cause the code to popup and not necessarly the one that is shown.
I had my check engine light on and the problem was the O2 sensor which I replaced. Then the traction light came on, so I fixed that. Now the check engine light is back on, as is the traction light. I have been told that the check engine light is on because the catalytic converter needs replaced. Has anyone else experienced the same issue? And would this have any affect on the traction light problem?
