Anybody have this code before? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 03-03-2006, 09:12 AM   #1 (permalink)
View 99solarav6's Photo Gallery
The check engine light came on for my gf's 99 solara v6. We went to shop to find out what's wrong and it came up with code 171 (Fuel System Lean). When they check further they found a leak in the power brake booster. They said I need to replace that and it'll fix the problem. Anybody have this problem before? Also what's best place to buy oem parts?
99solarav6 is offline   Reply With Quote
Old 03-03-2006, 02:39 PM   #2 (permalink)
MDT Toyota Tech
View BadChicken's Photo Gallery
i see p0171 codes all the time at work. It indecates that you either have a vacuum leak or your mass air flow (MAF) sensor is bad. Very common problem on the 1mz motors. almost 9 out of 10 times its the MAF, costs somewhere around $150 for the part. but in your case it sounds like it may be a vacuum hose. keep us posted on it
BadChicken is offline   Reply With Quote
Old 03-04-2006, 08:46 PM   #3 (permalink)
im a chong.
View thcfortified's Photo Gallery
i have to agree with badchicken on the MAF.
need to do an active test and check the fuel trim.
if your booster line had a leak, you'd feel it in the brake pedal.
and the best place to get oem parts is ... your local Toyota Dealership.
Toyota Tech.
give me all the diag, check engine lights, warranty work, i dont care. i dont to make 40hrs. i love guaranteed time.
thcfortified is offline   Reply With Quote
Old 03-08-2006, 09:25 PM   #4 (permalink)
The shop where I went to said it's the power brake booster because there is leak. I asked if I can just replaced the vacuum lines but they said I need to replaced the booster itself. I can feel it in the brake pedal so that was the right dignostic. Thanks for your input guys.
2000 Toyota Corolla VE Trouble Code help??? hssaini Archived Corolla threads 3 07-28-2006 10:02 PM
why am i getting code 52 eyz closd MR2 Forum 7 01-10-2006 08:36 AM
Camry Color Code Confusion jck91camry Camry & Solara Lounge 7 06-22-2004 12:19 AM
Check Engine light Code 25 & 26, please HELP!! xaznxeclipsex MR2 Forum 0 06-01-2004 08:46 PM
ecu trouble code Nx2k Archived Corolla threads 1 02-12-2003 06:36 PM
