changing rear brake light bulb - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 03-08-2006, 01:02 AM   #1 (permalink)
View Guamaniac's Photo Gallery
Hello all....I tried the search function but didn't get any results...So I just wanted to know....Does any1 have a link that explains my topic or is able to give a quick run through on how to change out a brake light bulb for the rear driver side on a 2001 solara? I would think that the brake light cover assembly either pops off or screws off, but I just wanted clarification if someone has gone on and replaced a bulb already on a solara..Thanks all...
Guamaniac is offline   Reply With Quote
Old 03-08-2006, 01:06 PM   #2 (permalink)
MDT Toyota Tech
View BadChicken's Photo Gallery
i believe you just have to pull back the carpet in the trunk and you should be abel to access the bulbs, just turn the socket that contains the burnt out bulb and remove it
BadChicken is offline   Reply With Quote
Question Bulb Type for rear turn signal cman2000 Camry & Solara Lounge 3 03-24-2005 10:53 PM
DIY - MORE LIGHT (9005 bulb mod) - Corolla FAQ addition BLUEMEANIE Archived Corolla threads 0 03-23-2005 11:26 AM
How to change 3rd brake light bulb? MattZ28 Camry & Solara Lounge 2 11-09-2004 01:06 PM
Rear brake squeal on an '03 LE (drum) Corollaized Archived Corolla threads 0 10-15-2004 07:05 PM
gen2 brake light stays on... help... please.. busted_ride 1st & 2nd Generation (1983–1986 & 1987-1991) 2 09-24-2004 04:56 AM
