99 Solara Heater only works on High - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 03-08-2006, 08:08 AM   #1 (permalink)
View Doyle670's Photo Gallery
Now i've searched thru the forums and have found that this problem seems to be related to a bad resistor behind the glove box. But I also noticed that most of the time it was for a vehicle other than a Solara. I just wanted to make sure that the problem would be similar on a 99 Solara before I go and buy a resistor.
Also, does anyone know what the exact name of the resistor is when ordering it from a dealer.
Thanks a bunch.
Doyle670 is offline   Reply With Quote
Old 03-08-2006, 09:31 AM   #2 (permalink)
Ferocious Teddy Bear
WortownSolara's Avatar
View WortownSolara's Photo Gallery
does your ac work on low?
If it doesn't kill you, it only makes you faster!
WortownSolara is offline   Reply With Quote
Old 03-08-2006, 10:05 AM   #3 (permalink)
I don't think so....although I don't know if i've tried....
Old 03-09-2006, 09:38 AM   #4 (permalink)
ok, well check that, find out if your fan is actuall turning on at the lower levels. It still could possibly be the switch itself, maybe even the blower. The camry resistor issue was pretty specific to that vehicle and model year. To my recolection, none of the solaras around here have had this issue. Do a little bit more as far as information gathering, and we should be able to poitn you in the right direction.
Old 03-09-2006, 07:43 PM   #5 (permalink)
View 02Wiley's Photo Gallery
Resistor
You need to check you blower motor resistor. When on high it bypasses the resistor so the motor get source voltage. When on low any of the other settings it goes through the resistor so the motor can run at different speeds.
02Wiley is offline   Reply With Quote
99 Solara gfreek Solara 5 04-30-2006 12:04 PM
FS: 99 Toyota Solara SLE V6! 99solarav6 Vehicles 1 03-05-2006 09:34 PM
Explain to me how 4x4 works in my 99 4runner j7b 4Runner Lounge 3 01-27-2004 05:46 PM
Fan switch problems, only HIGH works WASABI Celica Forum 3 07-29-2003 01:52 PM
