How to check/reset airbag light on 99 solara? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 04-10-2006, 01:56 PM   #1 (permalink)
View 99solarav6's Photo Gallery
I notice couple of days ago that on my gf's 99 solara v6 that the airbag light came on. Right now it's just blinking off and on. Is there anyway to check to see what's wrong without taking to dealership?
99solarav6 is offline   Reply With Quote
Old 04-10-2006, 08:12 PM   #2 (permalink)
View noodlerooney's Photo Gallery
Yes, the procedure for checking/resetting the SRS diagnostic system is described in detail in the Factory Service Manual.
Lots of times, the wiring connection under the front seat(s) has been kicked loose (yellow connection).
Disconnect negative post of battery and wait 90 seconds before attempting to check/reconnect.
By the way, if the airbag light is blinking, the airbag system (SRS) is disabled.
00 Solara SLE V6 1MZ-FE, 16.5K miles "Garage Queen"
94 Camry LE I4 5S-FE
noodlerooney is offline   Reply With Quote
Old 04-10-2006, 08:40 PM   #3 (permalink)
I will check the connection to see if it's loose. Then I'll disconnect the battery and plug back in to see if that fix the problem. Thanks for info.
History of the Toyota Solara Ratko Solara 17 05-28-2011 08:49 PM
Gen 1 - Gen 5.5 massive compile of bulb info ASG14 1st & 2nd Generation (1983–1986 & 1987-1991) 20 01-03-2006 03:51 PM
99 4Runner Engine Light "ON" XPY 4Runner Lounge 7 12-14-2005 08:46 PM
Airbag Light 92_Gen3_5SFE_LE Camry & Solara Lounge 1 10-09-2005 10:07 AM
Solara Light Wire Connection! Help! YMM Solara 0 04-01-2002 02:23 PM
