2000 SLE Disc Brake - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 04-21-2006, 09:46 PM   #1 (permalink)
View mh808's Photo Gallery
2000 SLE Disc Brake
Hey, I need to replace my disc brake pads. The discs surface is still nice and flat and smooth. Think I need to cut and resurface them or can I just changeout the pads? Anybody just replaced their pads without cutting their discs? Any problems with squealing or chattering?
mh808 is offline   Reply With Quote
Old 04-21-2006, 09:52 PM   #2 (permalink)
Noob :-)
View ST185's Photo Gallery
Depending on the condition of the rotors, you can replace just the pads without turning (resurfacing) the rotors.
93 ST185
ST185 is offline   Reply With Quote
Old 04-23-2006, 03:09 PM   #3 (permalink)
Gangsta SC400 & 5.7Tundra
iTrader Score: 35 reviews
View -SCWEET1-'s Photo Gallery
you are fine.. if the rotors do not seem warped its okay to do.
-SCWEET1- is offline   Reply With Quote
Old 04-24-2006, 09:28 AM   #4 (permalink)
What the Pho?
View SolaraTRD's Photo Gallery
how many miles you got on her?
~TN.com Unofficial AIM list~ Updated: 2-23-08
SolaraTRD is offline   Reply With Quote
Old 04-24-2006, 09:21 PM   #5 (permalink)
I only got 26K miles but most of it is city driving. Not much highways and byways in Hawaii. Well, the rotors look flat and the surface is smooth with no grooves. I'll try to replace the pads first and see what happens. If it start to squeal, I guess I can take them off and get the rotors resurfaced then. Or will I have damaged the pads by then?
Old 04-29-2006, 07:57 PM   #6 (permalink)
View marc780's Photo Gallery
If the rotors are smooth you can change pads without turning. BUT you should break the glaze from the old pads first to get the best braking. Just use a piece of fine emery clothe (not sandpaper!) and sand/polish your rotors for a minute or two. Sand across the surface not round and round. One or two trips around the rotor, both sides, ought to do it. Then just clean it up with some brake cleaner and youre ready to put in the new pads.
Rear disc brake drag - HELP! jeffstar General Lexus Discussion 2 08-11-2006 11:16 AM
just done my rear disc brake conversion now starts the problems gasman Archived Corolla threads 30 06-02-2006 01:39 AM
Avalon rear disc brake fit on a gen4 cam? RED171 3rd & 4th Generation (1992–1996 & 1997–2001) 2 11-30-2005 08:47 AM
Rear Disc Brake Conversion for 94-97: Doable? deramg Archived Corolla threads 9 01-08-2005 02:08 AM
2000 Camry, Brake upgrade recomendations aleks77 3rd & 4th Generation (1992–1996 & 1997–2001) 3 11-05-2004 11:50 PM
