Air Conditioning Problem... - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 05-09-2006, 01:15 PM   #1 (permalink)
PDM
View PDM's Photo Gallery
Question Air Conditioning Problem...
Solara 2000 - Come On People - Please Help. I posted a thread regarding water in my rear foot-well. I now know that the water is coming out of the AC Vents under the passenger seat. This happens once the car has stopped with the engine off. I also noticed that there is no water (drip) appearing under the car as it used to. Someone must have a handel on this. Please help. Thanks.
PDM is offline   Reply With Quote
Old 05-09-2006, 03:01 PM   #2 (permalink)
Dave's
Gameroom cash: $124850
View Dave's's Photo Gallery
There should be a tube snaked down from your AC under the dash and thru a hole in the floor. Probably against the firewall and under the carpet. (Look at where the carpet stops up under the dash for a 'probably' black rubber hose.) Sounds like it's clogged. You might crawl under the car and run a stiff but flexible wire or rod thru it. Or if you can pull it loose from the AC unit you can clear that hole and the hose from inside.
Dave's is offline   Reply With Quote
Old 05-10-2006, 11:10 AM   #3 (permalink)
PDM
Thanks.
Thanks. I'll have a go. I appreciate the advice.
Old 05-14-2006, 08:39 AM   #4 (permalink)
MDT Toyota Tech
View BadChicken's Photo Gallery
sounds like the hose in stuck under the carpet, just pull up the carpet and put the hose back through the floor opening
BadChicken is offline   Reply With Quote
Idle when air conditioning is on 1122union Camry & Solara Lounge 11 04-07-2006 05:30 PM
car wont start, hearing air through the lines...weird problem. afyouthbrigade Camry & Solara Lounge 2 11-07-2005 06:58 AM
GEN 5 Owners: Air Conditioning On or Windows Down ... Which Consumes More Gas??? LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 14 06-20-2005 11:31 PM
03 corolla cold air intake problem totlll Archived Corolla threads 11 04-20-2004 06:00 PM
Air Conditioning notsmartguy Archived Corolla threads 11 04-20-2004 05:54 PM
