2000 V6 Transmission Drain Plg Stuck - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 06-10-2006, 08:18 PM   #1 (permalink)
View clarkman's Photo Gallery
I am trying to drain my transmission fluid but I can't get the drain plug out. I have used a socket wrench and a T-Style Hex Key but I can't get the plug loose. Does anyone have any suggestions?
clarkman is offline   Reply With Quote
Old 06-11-2006, 02:12 PM   #2 (permalink)
MDT Toyota Tech
View BadChicken's Photo Gallery
the plug is usually a little tight but if your using a 10mm Hex and a ratchet you should be able to loosen it with a little pressure
good luck
BadChicken is offline   Reply With Quote
Old 07-05-2006, 05:40 AM   #3 (permalink)
Darkside Cut Me!!!
Gameroom cash: $136123
View Hajoca's Photo Gallery
How are you doing with the drain bolt removal??
The threads are usually precoated with a thread lock/ sealer... so do that when it is warm, or use a bit of heat.
Tightening it will break the thread lock, so try that a few more times.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 07-30-2006, 04:50 PM   #4 (permalink)
View marc780's Photo Gallery
By now im sure you have got that plug out somehow..but anyway here are some tricks for loosening stuck fasteners i have used -
*tap the fastener with a hammer. Dont beat on it, just gently tap it. You should not be leaving any tool marks, just go tap tap tap for about 30 seconds. It doesnt hurt to douse the fastener with wd-40 or something close either.
And when this gets old, try loosening the faster now, it might come loose. If not - on to the next one!
*put a wrench on your hex wrench you are using on this drain plug. To give you more leverage - hold it close to the fastener hole for leverage.
*Heat - low flame from a propane torch (last resort). I mean LOW the lowest it will go. A heat gun might be safer and might help too. Apply heat to the fastener for 30 seconds or so, keep the flame moving. Shut off flame, try removing fastener.
*Use a breaker bar on your wrench, anything that will extend the handle; again, to get more leverage.
*Try TIGHTENING instead of loosening! For some bizarre reason this often works. Putthe wrench on, now tighten for a second or two Try to loosen again. Now tighten again. Loosen. You get the idea.
Any or all of these tips ought to help you get that plug out. And right about now i'd be vowing never to put my car again in the hands of the idiots from jiffy lube or whatever place tightened that plug so damn much!
Transmission leak - 1999 V6 5-speed Wilbur 3rd & 4th Generation (1992–1996 & 1997–2001) 4 06-04-2006 01:16 PM
V6 Camry Manual Transmission??? REAPER STRAIN Camry & Solara Lounge 10 08-13-2005 11:26 AM
2000 Camry Tranmission Drain and fill ptran 3rd & 4th Generation (1992–1996 & 1997–2001) 4 07-09-2004 03:15 PM
stupid stuck transmission - HELP, Please! 89alltracAuto Camry & Solara Lounge 2 02-07-2004 05:26 PM
