power fluctuations / lights getting dimmer & brighter - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 06-12-2006, 11:44 PM   #1 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
European Union power fluctuations / lights getting dimmer & brighter
Hi,
I have bought used 2000 Solara 2.2L I4 some time ago and since the beggining I experience some trouble with electric power fluctuations. Mainly it is perfectly visible at night, basically all lights (external & internal) including dashboard control lights get dimmer & brighter every second. It happens only when engine is running. When I shut down the engine such behaviour stops immediately.
Already replaced battery and this problem still persists. Could it be a faulty alternator? ECU doesn't show any error on that and the seller says it's always been like that... no comments.
Old 06-12-2006, 11:56 PM   #2 (permalink)
View nyyankees3511's Photo Gallery
My car is like this too.
nyyankees3511 is offline   Reply With Quote
Old 06-13-2006, 12:24 PM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
European Union hmmm, anyone else has the same problem?
that's weird. at least I am not alone with this problem... guys? anyone else expereinced the same problem with solara?
Old 06-13-2006, 03:13 PM   #4 (permalink)
What the Pho?
View SolaraTRD's Photo Gallery
Try this...
When parked at night with the headlights and fogs on... Look at your cluster. Rev the engine (very lightly will do) and do you notice the cluster/dash lights kinda get a bit brighter... then back to dim again when the revs goes back down?
As long as the lights/car doesn't go all the way off or to a point where you can't read the gauges, its normal. Electrical drain from everything running, especially when those headlights are on.
~TN.com Unofficial AIM list~ Updated: 2-23-08
SolaraTRD is offline   Reply With Quote
Old 06-14-2006, 12:45 PM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
European Union this is it! all lights flicker, visible at night and rainy weather...
Yes CSAXON, this is it. I will check alternator if disconnecting it helps (probably not), anyway needed to change the battery some time ago but it didn't solve the problem. The worst flickering I noticed with road map light, it makes me feel sick...
But... the problem is the air /fuel sensors are coming on at the same time, so replacing them is not gonna fix it, right? ultimate question is how da hell I fix it
Let me know if I only need to replace A/F sensor with a new one or I need Toyota dealer to reload the ECU software with updated version...
My car is 2000 and it has only 37K miles. Should I go to dealer for reprogramming of the computer? How much do they charge for something like it? I think that if Toyota admitted the problem thaey shall fix it for free since this is THEIR fault... any suggestions? should we contact Better Business Bureau www.bbb.org?
Thanks!
Old 09-19-2006, 01:41 PM   #6 (permalink)
抵抗は無駄です
fenixus's Avatar
European Union what a shame :)
Hi everybody.
writing now, but 2 months ago discovered the most stupid reason of lights flickering in the world and still ashamed to admit it here
well, ehhm the reason of my problem was one loose screw (one out of 2) on positive connector of the battery
once the screw was tightened the flickering disappeared. well maybe it's funny but also error code P0505 (IAC valve) is gone since that time. Looks like no more problems with my Toyota since that time, I additionally did transmission service including filter & fluid change so now my Solara runs smooth and nice.
really like this car finally
Thanks to all fr diagnosisng and good luck with your rides!
Old 09-19-2006, 03:43 PM   #7 (permalink)
View ozarkpreacher's Photo Gallery
these type problems can nearly always be traced back to a poor ground connection. Not always but...
ozarkpreacher is offline   Reply With Quote
Old 09-27-2006, 09:56 AM   #8 (permalink)
What the Pho?
Glad we got a good outcome
Brighter backup lights?? jetfishn 2nd Generation (2005+) 41 10-12-2006 06:37 PM
Making some cool power (caution! For reference use only ) AngryAE101 Archived Corolla threads 5 11-03-2003 10:03 PM
How much RMS power is enough to power 2 JL 12W3 subs????? smokiz Audio, Video, and Security - Tech 7 02-17-2003 01:44 AM
CAN MY GAUGE LIGHTS GET BRIGHTER? spills1969 Camry & Solara Lounge 4 12-13-2002 11:45 AM
gen 4 dimmer problems or dimmer problems in itself. Bigshoguns 3rd & 4th Generation (1992–1996 & 1997–2001) 4 10-21-2002 08:55 PM
