Water Leaking Inside... - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 08-03-2006, 07:43 AM   #1 (permalink)
Omes01SLE's Avatar
View Omes01SLE's Photo Gallery
I went to my car the other day to literally find a puddle of water in the driver's footwell, as well as behind me in the backseat. The carpet is literally drenched - the water is not coming in from outside (as it has not rained in weeks), my beleif is that it is coming from the A/C unit somehow.
I don't know if the original water drain plug has been blocked and now the water is overflowing inside, but when I look under the car I can see the water droplets formed right under the driver/passanger side.
The other negative of this, is that I guess there are electrical wires running under the carpet and now with the water all my bulbs are shorting out!
Any help/info would be appreciated.
thanks.
Omes01SLE is offline   Reply With Quote
Old 08-03-2006, 07:08 PM   #2 (permalink)
View toyomoho's Photo Gallery
Make sure it is not coolant water from the heater system. The A/C drain hose could be plugged, this seems to happen frequently. I think the drain hose going out the bottom is hidden a little. As such you might need to go under the car to see it. Try cleaning it out with a coat hanger wire, etc. If not either of these check the TN post on this subject at the end of these postings.
Old 08-07-2006, 07:45 PM   #3 (permalink)
View igt123's Photo Gallery
thanks.
If its a 2004 and one of the first 6000 or so made there's a TSB out there.
If not then you are probably correct in your assumption. I.E. a leaky hose from the A/C. - Hope that helps
igt123 is offline   Reply With Quote
Old 08-15-2006, 07:54 PM   #4 (permalink)
View dascjp1's Photo Gallery
I have a 07 SLE V6 - imagine my surprise when at less than 500 miles I had water running into the car from the bottom of the door windows!! When it rained or I washed the car water would run into the car and accumulate in the car. Come to find out I need weatherstripping in the windows....there wasn't any....they had forgot!! So now it is on order.
Maybe this is your problem, wouldn't hurt to check.
dascjp1 is offline   Reply With Quote
Old 08-16-2006, 01:47 AM   #5 (permalink)
Yes, thought the TSB said something about the vent flaps in the rear not working right allowing water to come into the car. Can’t remember the details.
Oil in water '93 pickup, 22-RE fairlanegt428 89-95 Toyota Pickup/Hilux 4 02-20-2012 07:50 PM
Water leaking on passenger's floor area! RedRacer Camry & Solara Lounge 15 06-12-2006 01:53 PM
Water spill....carpool carwash asking $350 to fix png6778 General Discussion 10 05-04-2006 11:08 PM
car into puddle of water: stopped please help celica2004 Archived Corolla threads 1 04-30-2006 03:04 AM
Water pressure problem > radiator cap ? Nico Camry & Solara Lounge 9 08-31-2004 12:03 AM
