Solara - Rough Idle from cold, progress into misfire/lack of power - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 10-16-2007, 01:26 AM   #1 (permalink)
View Toyotaturd's Photo Gallery
Several weeks ago, my 99 Solara with 125K started to experience a rough idle in drive mode when cold. This has progressively got worse into random misfiring and lack of power on hard excelaration. I changed the plug wires and plugs, replaced the fuel filter and idle control valve. I suspected bad gas, so I tried an additive in tank, which also didnt work. Check engine flashes and produces P1300. I was advised that the injectors may be possibly blocked, but not convinced because the car runs smoothly when warm and not driving hard. Car idles okay, when warm. When engine is warm from idle, upon snaping throttle, misfire is detected. Potential coil failure? If so, would I experience a misfire on 2 cylinders (wasted spark system) Any other ideas welcome. I have thrown parts at the car, and dont really feel confident about the next move. Thanks.
Toyotaturd is offline   Reply With Quote
Old 10-24-2007, 09:39 PM   #2 (permalink)
View rone_305's Photo Gallery
Igniter Circuit Malfunction.......Thats ur problem
rone_305 is offline   Reply With Quote
Old 10-26-2007, 11:20 PM   #3 (permalink)
Every Day Driver
jhmesquire's Avatar
View jhmesquire's Photo Gallery
Question
What do you mean? I would try a bottle of water remover and a tank of 93, or professional fule system cleaning
jhmesquire is offline   Reply With Quote
Old 10-26-2007, 11:21 PM   #4 (permalink)
Every Day Driver
jhmesquire's Avatar
what kind of mpg are you guys getting??
Old 10-27-2007, 02:15 AM   #5 (permalink)
naw its not that,its eletc. take it to the dealer they will fix that every quick not cheap but quick stop wasting money on bulls*** have that fix right away it will miss up ur engine
Old 10-27-2007, 02:16 AM   #6 (permalink)
a car cant be going thru rough idle
Old 02-04-2008, 11:56 PM   #7 (permalink)
View usacmidget's Photo Gallery
Problem
Did you ever figure you the problem for your car. I have a 2000 Solara 4cyl and am experiencing the similar thing. I have had codes P0301 and P0300 come up. I have a rough idle most of the time but especially when its cold. I have changed the plugs, coil, Injector, and have run fuel cleaner through the system. Someone told me that maybe the ECU could be an issue in these cars? Anyways if you can let me know what happen to your car and maybe any ideas on my car would be great. Thanks.
usacmidget is offline   Reply With Quote
Old 02-05-2008, 08:00 PM   #8 (permalink)
View synenergy52's Photo Gallery
Spark plug wires.
I've experienced this in two other Camry 4 cylinders. It'll drive fine under light acceleration but once you give it gas, it will require more "spark"... spark that can't travel through worn wires--thus the misfiring or feeling like its driving on half the cylinders.
If you're over 100k, you're well over due.
synenergy52 is offline   Reply With Quote
Old 02-28-2008, 03:37 PM   #9 (permalink)
ksexton13
View ksexton13's Photo Gallery
Spelling
Why can't anybody in this thread spell?
Have you fixed it? I am having the same problem with a 1MZ. Drove it with a scanner hooked up and had 2 and 4 misfire. Switched the ignition coil and moved the idle misfire from 1 to 5. It all started after a fill-up, though, so I'm a little suspicious. May try some 93 and a fuel system cleaner...
ksexton13 is offline   Reply With Quote
Old 02-28-2008, 05:39 PM   #10 (permalink)
wont change nothing if you switch to a higher octain....just do the same thing you did to 2 and 4
Rough idle cozmo_im 6th Generation (1988-1992) 2 11-05-2008 12:29 AM
Rough Idle b_driver 3rd & 4th Generation (1992–1996 & 1997–2001) 12 09-28-2007 03:56 AM
cold idle rpm erquan Camry & Solara Lounge 4 01-29-2006 01:06 PM
94 Tercel rough idle when cold atoyotchick Tercel, Paseo, Starlet, and Sera Forum 7 11-15-2005 11:10 AM
Making some cool power (caution! For reference use only ) AngryAE101 Archived Corolla threads 5 11-03-2003 10:03 PM
