!!!HELP!!! my 1mz fe gets 18mpg - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 10-23-2007, 09:34 PM   #1 (permalink)
Every Day Driver
jhmesquire's Avatar
View jhmesquire's Photo Gallery
Exclamation !!!HELP!!! my 1mz fe gets 18mpg
I noticed my poor milage a while ago. since then I have tried...
Replace air filter
cleaned the MAF
used a fule cleaner (about 5 times)
replace the plugs
replaced the wires
Changed the oil (synthetic as always)
Changed the Tranny fluid
I am thinking it might be the cat. I dont have any lights on, and
the ecu isnt throughing any codes. Its an automatic and I don't
drive it hard, just average daily driving. I used to get high 20s,
and the price of gas lately 10 mpg is a real big deal.
what kind of gas milage are you guys getting in your 1mz fe 3.0 v6s, and
any ideas why my mpgs are so low???
jhmesquire is offline   Reply With Quote
Old 10-23-2007, 09:57 PM   #2 (permalink)
Every Day Driver
jhmesquire's Avatar
I have also already gotten an alignment
I have costco tires BFGs so I keep them rotated and
correctly inflated (w/nitrogen)
Old 10-24-2007, 07:31 AM   #3 (permalink)
93 240sx SR Hatch
DAMON's Avatar
iTrader Score: 36 reviews
View DAMON's Photo Gallery
I get about 25-28 mpg with a good city/highway mix supercharged. You should definitely be getting better mileage... fuel filter perhaps?
94 Camry (Beater) 99 Solara (Totaled) 93 240SX (Current)
DAMON is offline   Reply With Quote
Old 10-24-2007, 10:57 AM   #4 (permalink)
Every Day Driver
jhmesquire's Avatar
I don't think any one replaces the fule filter as offton as recomended. I think I might give that a shot. I did it once when I first got the car, who knows.
I didn't mention in my original post but my car is lowered 1.6". I would think that it would help fule economy via less drag.
Old 10-24-2007, 05:07 PM   #5 (permalink)
JDMGUY3's Avatar
View JDMGUY3's Photo Gallery
yea im getting about 24 per gallon
Rice Stompin daily kid!
JDMGUY3 is offline   Reply With Quote
Old 10-28-2007, 09:52 PM   #6 (permalink)
Every Day Driver
jhmesquire's Avatar
Replace air filter
cleaned the MAF
replace the plugs
replaced the wires
well since then I have tryed something I should have thought of a long time ago. I got gas some wher besides my normal place. I always use 93 and since the new station Ive been getting much better millage my avg now is 26 mpg. I think I am a victim of watered down gas.
Old 10-28-2007, 11:28 PM   #7 (permalink)
Every road's a playground
toyotaholic's Avatar
View toyotaholic's Photo Gallery
whats are your driving habits?
toyotaholic is offline   Reply With Quote
Old 10-28-2007, 11:29 PM   #8 (permalink)
JDMGUY3's Avatar
im pretty agressive. I love the corners
Old 10-29-2007, 12:24 PM   #9 (permalink)
Every Day Driver
jhmesquire's Avatar
pretty mild hwy city mix
Old 11-03-2007, 01:45 AM   #10 (permalink)
could be a lot of things, try going easy on the gas pedal and less aggressive driving. on the fwy i always drive 65 or follow the speed limit. o yea, get rid of any junk in your trunk
Old 11-06-2007, 02:05 PM   #11 (permalink)
Every Day Driver
jhmesquire's Avatar
Exclamation
If I drove aggressively I would expect lower mileage. However, since I do drive "easy on the pedal" I am concerned about the low millage. As for the trunk. Its empty, much like the thought you gave to this response.
Thanks for nothing!
Old 11-06-2007, 02:26 PM   #12 (permalink)
Blaaaa.blaaa.blaaaa
View l-man08's Photo Gallery
Remove all the weight in your trunk, or the stuff you don't need... This will get a 2mpg increase. Also are you using low friction synthetic oil? Try to get pure acetone. Fill your tank to 3/4, and put in (pure acetone only)about 2 ounces every fill-up... You will get at-least a extra 10mpg. Check those tires.... Your pcv valve, or oxygen sensor.
http://www.pureenergysystems.com/new...00069_Acetone/
old-n-sold---Stock 01 Burgundy Camry-4cyl, 4spd auto, 30% tint
Mileage 81,050.
NEW --05 Camry V6 XLE bought with 38,XXX Miles Pictures to come soon.. Will trade in for 09 XRS 5 speed, when it comes out----
l-man08 is offline   Reply With Quote
Old 11-06-2007, 04:32 PM   #13 (permalink)
93 240sx SR Hatch
DAMON's Avatar
there is obviously something wrong with the car guys... i think he is looking for an answer as to what may be wrong with it, not tips on how to increase his mileage...
Old 11-07-2007, 08:27 AM   #14 (permalink)
Every Day Driver
jhmesquire's Avatar
Exclamation
Thank you
The only symptoms are:
1) Bad gas millage
2) Sluggish acceleration
a. On the road if I try to go from 30mph to 40mph The engine revs to like 3500 but I get to 40 very slowly. (like a small truck hauling a big boat)
Has anyone with a Solara, Camry, Privia, Avalon, or any other 1MZ FE based 3.0L had a problem like this before??
Old 11-09-2007, 08:00 PM   #15 (permalink)
Every Day Driver
jhmesquire's Avatar
Unhappy
Replace air filter
cleaned the MAF
replace the plugs
replaced the wires
I checked the plugs again. A little oxidized, I replaced them with Iredium NKG
Engine is ideling smoother and I'm up to 21 MPG.
I was using the NKG split fire platinum plugs, it is the same plug that was in there from the factory, but these didn't last as long they were gray on one side and tan*ish orange on the other. I think this means detergint in gas.
I don't think the plugs are the only problem, so I ordered some 8.5mm Magnecor wires hopefully this may help.
I really did think more people would have responded.
1zz fe VS 2zz fe Crowbar911 Archived Corolla threads 4 04-07-2010 10:56 PM
1mz fe passenger cv axle removal amekaji87 3rd & 4th Generation (1992–1996 & 1997–2001) 9 06-09-2007 08:47 PM
1mz or 3vz - whats your favourite? v-cam 3rd & 4th Generation (1992–1996 & 1997–2001) 18 02-28-2007 08:02 PM
Engine swap for gen 4 war0827 3rd & 4th Generation (1992–1996 & 1997–2001) 77 06-29-2004 09:59 PM
