trouble codes! need help - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 10-30-2007, 06:52 AM   #1 (permalink)
View rollinlarge's Photo Gallery
ok this is my wifes car. she has put about 25k on it this year (trip to cali and back)
well semi recently i changed the front pads, turned the rotors, new fuel filter.
well all of sudden today she is driving home and her car starts idling funny and stalling etc.
these are the codes
P0300-random multiple cylinder misfire
P0303-cylinder 3 misfire detected
P0306-cylinder 6 misfire detected.
it all of a sudden just happened yesterday night.
what could it be?!!? any help is greatly appreciated!!!
thanks
99 toyota solara, 3.0, V6, auto 143k (well maintained and taken care of)
rollinlarge is offline   Reply With Quote
Old 10-30-2007, 08:34 AM   #2 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
these are the codes
thanks
Look to the ignition coils. The three coils in the front provide spark for the cylinder they sit on top of as well as a cylinder on the opposite bank connected via a high tension wire. The front coils sit on cylinder #s 2, 4, and 6, so trace the wire from the coil on 6 over to the other side and see where it goes. If it ends up on cyl 3, you have a good idea that the coil may be at fault.
Another strategy you can take is to clear the codes, swap coils, and take it for a drive to see if the code moves with the coil.
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline   Reply With Quote
Old 10-30-2007, 01:26 PM   #3 (permalink)
so where are they?
i looked online and some autoparts sites say it has 3 coils and some say 6?
is it direct ignition?, distributorless?
because its being looked at right now and i imagine your right
Old 11-01-2007, 07:38 PM   #4 (permalink)
fixed
damn coil like i thoguht and everybody said!
thxs
Old 11-18-2007, 08:33 PM   #5 (permalink)
View rone_305's Photo Gallery
its the spark plugs....make sure they are connected and they are not loose
rone_305 is offline   Reply With Quote
Old 11-18-2007, 09:36 PM   #6 (permalink)
pls read above, had the coil replaced that was the problem
Old 11-19-2007, 05:46 PM   #7 (permalink)
my bad
Old 11-19-2007, 05:51 PM   #8 (permalink)
View bonecrusher's Photo Gallery
my bad
hey np!
bonecrusher is offline   Reply With Quote
Old 02-20-2008, 10:50 AM   #9 (permalink)
View glicorish's Photo Gallery
I have a 99 Solara and I started getting similar codes most of the P300's codes are related. In my case I was also getting a foul smell, rotten eggs, in the car. Turn out to be O2 sensor after the catalysis. A user manual and a mulitmeter make life easy when you have codes to work with. The manual outlines the steps for trobleshooting each code and provide specifications for each sensor.
glicorish is offline   Reply With Quote
need help clearing trouble codes johnd1711 89-95 Toyota Pickup/Hilux 7 09-24-2007 09:58 PM
Have CEL, how do i get the trouble codes dangger RAV4 Forum 1 10-24-2006 07:40 AM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
Help! 2000 Sienna Trouble Codes vadad23 1st Generation (1998-2003) 0 12-09-2005 02:09 PM
trouble codes wannakno General Discussion 0 05-22-2003 01:07 AM
