Solara Daytime Running Lights - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 11-06-2007, 03:32 PM   #1 (permalink)
View cfree's Photo Gallery
HELP- Does anyone have directions on how to install daytime running lights on an 04 Solara??? They have to be set up so they cannot be manually shut off
THANKS
** THE LIGHTS HAVE THE AUTO FUNCTION- UPON WHICH THE DRL ARE ENABLED. HOWEVER THEY HAVE A "DRL OFF" FUNCTION ON THE TURN SIGNAL LEVER.
IN ORDER FOR THEM TO PASS STUPID CANADIAN LAW THEY CANNOT BE SHUT OFF WHILE DRIVING.
I installed DRL in a tundra and it was an easy 2 piece mod from Totoya. DOES ANYONE KNOW IF THE ELECTRICAL WORK IS SIMILAR IN MOST TOYOTAS??
THANKS!!
cfree is offline   Reply With Quote
Old 11-06-2007, 04:30 PM   #2 (permalink)
93 240sx SR Hatch
DAMON's Avatar
iTrader Score: 36 reviews
View DAMON's Photo Gallery
didnt they come standard? I know on the gen 1 they were standard...
94 Camry (Beater) 99 Solara (Totaled) 93 240SX (Current)
DAMON is offline   Reply With Quote
Old 11-06-2007, 09:36 PM   #3 (permalink)
electric-soLara's Avatar
View electric-soLara's Photo Gallery
so someone has disabled the DRL and you want to enable it back again?
electric-soLara is offline   Reply With Quote
Old 11-07-2007, 09:14 AM   #4 (permalink)
no they are enabled under the "auto" function. however they can be shut off by turning the lever to "drl off" do you a way to disable the "drl off" switch??
Thanks very much
Old 11-07-2007, 09:47 AM   #5 (permalink)
93 240sx SR Hatch
DAMON's Avatar
why do you need to disable the switch? just dont switch it...
Old 11-10-2007, 03:42 PM   #6 (permalink)
View lostru's Photo Gallery
I know what you are asking. Canadian law requires DRL's to be an automatic item with no way to turn them off. I am not familiar enough with the schematics to answer. There should be a performance electronic shop somewhere nearby that can answer.
lostru is offline   Reply With Quote
Old 11-10-2007, 04:27 PM   #7 (permalink)
^^ they do but I have mine disabled and I have had no problems with it, I only disabled mine cause of HID'S. I don't want them running all the time.
There are two ways they could have done it, the easy way is under the hood there is a grey plug that you can unplug plus the dash senor you unplug. The harder way is to clip the wire under the dashboard under the steering wheel.
1st issue with 07'Camry AESANTIAGO 5th & 6th Generation (2002-2006 & 2007-2011) 949 01-08-2008 02:49 PM
Camry Solara Melds Style And Comfort In Coupe And Convertible Models humanoid Toyota News 0 10-06-2007 03:06 PM
Daytime running lights turn off randomly... 1st_Cavalry 2nd Generation (2005+) 30 08-16-2007 11:06 PM
01 avalon Disable daytime running lights ryce4u 2nd Generation (2000-2004) 0 07-24-2007 12:14 PM
Disabling Daytime Running Lights ??? GogglesPaizano 2nd Generation (2005+) 24 10-31-2006 10:17 PM
