2001 Solara, 3 questions - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 11-10-2007, 02:55 PM   #1 (permalink)
View littleREDtercel's Photo Gallery
My daughter has an 01 Solara.
It has the 3.0, with a 5 speed tranny.
Milage is 69K........
1) Is this an interference engine?
2) What is the recommended interval to change the timing belt and
H2O pump?
3) Often, the car (while sitting still) won't go into either 1st or reverse.
I told her to put the car in 2nd or 3rd and let the clutch out a bit,
then shift into 1 or R. She says if she double clutches, then
usually it works. She let me drive it, and I couldn't get the car
into reverse, until I shifted into 2nd and rolled it forward about a foot.
littleREDtercel is offline   Reply With Quote
Old 11-10-2007, 03:29 PM   #2 (permalink)
93 240sx SR Hatch
DAMON's Avatar
iTrader Score: 36 reviews
View DAMON's Photo Gallery
I do not know the answer to the first question about the engine, but I do know that the timin belt interval is 90k miles, so you should be alright for a while. As for the first and reverse issue, my car does the same thing... If I just let the clutch out slightly and then put it back in it will go into gear every time. Not sure why it does that, but like you said double clutching does the trick.
94 Camry (Beater) 99 Solara (Totaled) 93 240SX (Current)
DAMON is offline   Reply With Quote
Old 11-10-2007, 03:35 PM   #3 (permalink)
Thanks for the info on the 90K, I was afraid it might be 60K.
I just did the timing belt on my other daughters Camry and that was more of a pain than I expected. Don't want to have to do another one so soon.
Old 11-10-2007, 04:54 PM   #4 (permalink)
93 240sx SR Hatch
DAMON's Avatar
^ understandable, I had the dealer do it because I was too nervous to tear it all apart... I helped my cousin do the timing belt on his Audi A4 and decided it wasnt worth it props for doing it yourself!
Old 11-12-2007, 10:56 AM   #5 (permalink)
Old Solaraguy User
View Akfahad's Photo Gallery
As Damon said, mine does the same thing about 1st and reverse. I just put it in neutral and let the clutch out and try it again. It always works.
Akfahad is offline   Reply With Quote
Old 11-14-2007, 10:34 PM   #6 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $398760
iTrader Score: 13 reviews
hmmm....really?
I have a 2000 solara e153 in my camry, and I don't have to do that.
I wonder if it's more of an issue with the stock clutch/flywheel? (I have a Spec stage III clutch and fidanza/spec lightweight flywheel
anybody on here with aftermarket clutch/flywheel?
HaHa
Old 11-14-2007, 10:41 PM   #7 (permalink)
TN Pussy Man
wait...akfahad...you're on sg, right? what boost are you running, and what setup do you have for your clutch/flywheel?
HaHa
Old 11-14-2007, 11:54 PM   #8 (permalink)
93 240sx SR Hatch
DAMON's Avatar
Im running an ACT street clutch and fidanza flywheel, had the issue with both setups...
Old 11-15-2007, 10:50 AM   #9 (permalink)
Originally Posted by Eye8Pussies View Post
hmmm....really?
My daughter isn't into after market up-grades.
She just wants to keep her stock ride running right, and not have to pay dealer prices for any repair work.
I told her that until the shifting either bothers her too much, or it leaves her stranded, to just live with it, as she found a way (double clutch) to make it work.
Thanks for all the reply's.......
Old 11-15-2007, 01:26 PM   #10 (permalink)
TN Pussy Man
hmmm....interesting. thanks for the knowledge as well guys.
but no complaints from me for my lack of the same problem though
but I'm sure that would probably piss me off to the point where I'd pull the whole damn thing out again to deal with it. lol
HaHa
Old 11-15-2007, 01:30 PM   #11 (permalink)
Small Potato
Matsu49's Avatar
View Matsu49's Photo Gallery
My trans was like that too. I wouldn't really worry about it. I think it just the way it is.
Matsu49 is offline   Reply With Quote
Old 11-15-2007, 02:39 PM   #12 (permalink)
93 240sx SR Hatch
DAMON's Avatar
yeah king, it isnt as bad as it sounds... itll just do it once in a while Ive noticed. I would be curious to know if there is a fix out there though...
Old 12-11-2007, 06:10 PM   #13 (permalink)
NYR
View IvanHoe's Photo Gallery
The IMZ-FE (3.0) engine in the Camry is non-interference, but in the Solara it is for some reason
I just bought a 1999 SE V6 5 speed w/90k so I will be doing it soon for sure
BTW , I havent noticed the reverse issue as of yet
1991 Corolla LE - 5 speed
IvanHoe is offline   Reply With Quote
Old 12-13-2007, 08:56 AM   #14 (permalink)
View joejv's Photo Gallery
H2O pump?
having just gone through a h2o pump and belts (serpentine, fan, timing) replacement on my 2000 solora with 60k and change, i can say it's 60k for inspection of pump, 90k for timing belt. however, as the pump i guess leaked on the timing belt, had to replace it early.
apparently, when toyota says "inspect and repld as needed at 60k" for the pump, they don't mean 60,001, or in my case, 60,454, they really mean 60k.
joejv is offline   Reply With Quote
Fairly Comprehensive factory 0-60 times under 6 sec. Rdizzle General Discussion 15 04-09-2007 10:12 PM
How do the cylinders count on 2001 Solara hambjs Solara 4 01-31-2007 02:55 PM
2001 4 cyl questions Reppinshadyvill 3rd & 4th Generation (1992–1996 & 1997–2001) 4 10-13-2005 07:00 PM
potential new solara buyer with questions dronek75 Solara 9 08-12-2005 05:11 PM
What gen is 2001, plus suspension questions mlbex 3rd & 4th Generation (1992–1996 & 1997–2001) 7 02-25-2004 11:56 PM
