Leaks - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 11-24-2007, 08:46 AM   #1 (permalink)
View lostru's Photo Gallery
Leaks
This is getting ridiculous. 5 trips to the dealer and still leaks in under the mirrors somehow. Its an 06 convertible and its making my life hard. I expect it to leak a little but this thing leave puddles. Any ideas on a fix or what did you have done to yours. Wifey was told by the salesman that "The convertibles of today do not leak". Now she is driving a car that she bought on her own and she is PI$$ED.
lostru is offline   Reply With Quote
Old 11-25-2007, 09:35 PM   #2 (permalink)
View littlebookworm's Photo Gallery
You should not accept the comment from the Toyota salesman. Cars are not SUPPOSED to leak, but obviously yours is. Go back to the dealer. Have them run a hose over the convertible top while you and a tech sit inside. If there's a leak obviously there will be signs of it. My Solara had a door lock problem which they couldn't find even after five tries. They only believed me when I got locked in in their parking lot. Go back and bitch. Good luck.
littlebookworm is offline   Reply With Quote
Old 11-26-2007, 08:58 AM   #3 (permalink)
Gadgetjq's Avatar
View Gadgetjq's Photo Gallery
Leakage around the mirrors shouldn't have anything to do with the convertible top (they're not even close to each other). Maybe there's supposed to be a gasket between the mirror and door that's missing?
I agree with the other forum member, hit the area around the mirror with spray from a garden hose (not a pressure washer) while someone is inside the car and see if you can track down the waters path into the car.
If it's the top leaking and not the mirror you can adjust the top so it latches a little tighter.
Cheers
Gadgetjq is offline   Reply With Quote
oil leaks 1996camry 5th & 6th Generation (2002-2006 & 2007-2011) 1 02-21-2007 06:40 AM
oil leaks 1996camry 5th & 6th Generation (2002-2006 & 2007-2011) 1 02-20-2007 11:55 PM
Barrs Leaks and overheating jeepnfl 3rd & 4th Generation (1992–1996 & 1997–2001) 9 01-01-2007 10:15 PM
Oil leaks on Gen 4 eyeball96 3rd & 4th Generation (1992–1996 & 1997–2001) 12 10-20-2005 03:56 AM
stripping paint off intercooler, cleaning, polishing, and checking for leaks crazy_camry Hardcore Tech and Competition 2 08-01-2003 06:18 AM
