What engine oil for 2006 v6 sle? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 12-14-2007, 08:43 PM   #1 (permalink)
View Haoest's Photo Gallery
Hello,
I have a 2006 Solara V6 SLE. I've always gone to my dealer for oil change. But since my recent relocation, I had to go to walmart for my last one.
So they put Pennzoil 5w30 (bulk) in it. I don' t know if it's because of the winter weather, my recent long road trip, or the cheap oil, my car has been louder than it used to be at first start up. Also, if I shift to D from Parking, and release the breaks immediately, the car tends to *jump* forward.
Am I over-paranoid, or should I sue walmart ?
What oil type should I use?
Thank you very much,
Hao
Haoest is offline   Reply With Quote
Old 12-14-2007, 09:33 PM   #2 (permalink)
View toyomoho's Photo Gallery
Read your owners manual. 5W-30 should be fine, Pennzoil is a good brand. Is the engine idle higher causing the car to move forward?
Old 12-14-2007, 11:32 PM   #3 (permalink)
I didn't bring it when I moved, and I can't find one online
And no, it just sounds slightly louder than usual.
Old 12-16-2007, 12:22 PM   #4 (permalink)
Gadgetjq's Avatar
View Gadgetjq's Photo Gallery
Originally Posted by Haoest View Post
I didn't bring it when I moved, and I can't find one online .
What, Google didn't find it? : http://gadgetjq.com/solara/maintenance.htm
First item on the page.
About the noise. Assuming it's a 'clattering' sound it seems to be normal for the V-6 engine at first start of the day using dino oil. Both my Solara and Highlander made the noise (I could only hear it with windows open or the top down) until I switched them over to synthetic (Royal Purple) oil. With the synthetic there's no more start up clatter.
Cheers
Gadgetjq is offline   Reply With Quote
Old 12-16-2007, 01:52 PM   #5 (permalink)
Brilliant, thanks for the link. I tried google, but after I sifted through a few pages of results, i gave up. they were all junk.
I am a newbie when it comes to cars. I've been reading about oil and I just want to confirm it. According to the chart on http://www.carbibles.com/engineoil_bible.html, it looks like 5w30 is semi-synthetic. If I put other types such as 5w40 or 0w30, will it harm the engine?
Thanks
Old 12-16-2007, 08:03 PM   #6 (permalink)
Gadgetjq's Avatar
5W-30 is just the weight (thickness or flow characteristic) of the oil. You can find it in every form, dino, semi-syn or full synthetic.
In addition to information in the owners manual you'll find the required oil type on the oil filler cap. Your engine is designed specifically to use that weight, any other won't provide the lubrication needed.
Cheers
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 11:48 AM
Toyota avalon 2007 time belt diagram drhusein 3rd Generation (2005-2012) 6 10-30-2007 07:35 PM
20R ENGINE REBUILD FROM HELL! (Part Three) nwdetectorist Pre-88 Toyota Pickup/Hilux 1 08-09-2007 07:30 PM
Can I use Synthetic motor Oil at 5k miles? Meteor_Proof 2nd Generation (2005+) 39 04-07-2006 01:00 PM
Mobil1 5w-30 Synthetic and my 2002 Corolla??? gadawg Archived Corolla threads 6 01-26-2004 04:39 AM
