Trac control inop - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Solara
Solara Forum for discussion and information related to all generations of the Toyota Solara. 1st Generation (1999–2003) 2nd Generation (2004–2009)
Old 12-18-2007, 06:27 AM   #1 (permalink)
jet2757's Avatar
View jet2757's Photo Gallery
Trac control inop
engine hesitated, nearly died, and then the traction off light illuminated. trac off switch not working?
jet2757 is offline   Reply With Quote
Old 12-18-2007, 06:42 AM   #2 (permalink)
View wangpang's Photo Gallery
What year is your car?
Does the trac light flash or just stay on?
Did your check engine light come on?
wangpang is offline   Reply With Quote
Old 12-18-2007, 08:10 AM   #3 (permalink)
jet2757's Avatar
2000. the light is not flashing. the ck eng lite had been previously illuminated due to O2 sensor issue.
Old 12-18-2007, 06:36 PM   #4 (permalink)
View toyomoho's Photo Gallery
In most systems if the check engine light is on, the TRAC system turns off to save engine power. Perhaps their is a pending engine trouble code in the ECU, have the codes reads.
Would look for the cause of the engine hesitation first, if found the TRAC issue may go away.
Old 12-18-2007, 07:25 PM   #5 (permalink)
Gadgetjq's Avatar
View Gadgetjq's Photo Gallery
If the car is running well enough to go the distance head for an auto supply store (Kragen, Autozone etc) that loans code readers. Plug the reader into your OBD II port (under the dash) and check the readout to see what the problem 'might' be. If the result is a little confusing write down the number and look it up online or call your Toyota dealer to see if they'll help you figure it out.
Cheers
Gadgetjq is offline   Reply With Quote
Old 12-19-2007, 06:30 AM   #6 (permalink)
jet2757's Avatar
History:
Originally when the cel came on I went to autozone and had them read the code. I was told O2 sensor, 1st bank. They cleared the code and told me if the cel comes back on to get the sensor changed. The performance of the car had not been effected. Within a few days the car had the engine hesitation and trac lite issue.
I disconnected the battery to reset ecu, and the "trac off" lite did not come back on. The trac off switch on the console was working as advertised.
I lost traction on the ice a few days ago and the trac off lite illuminated, and the switch on the console does nothing again.
Will changing the O2 sensor effect the trac sys?
Old 12-19-2007, 02:58 PM   #7 (permalink)
jet2757's Avatar
autozone visit this afternoon revealed only 1 code. P0135.
Last edited by jet2757; 12-19-2007 at 02:59 PM. Reason: where is this sensor located, p/n?
Old 12-19-2007, 03:20 PM   #8 (permalink)
Gadgetjq's Avatar
The book says that's: P0135 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #1)
Old 12-19-2007, 03:25 PM   #9 (permalink)
jet2757's Avatar
location would be at the firewall? is this the same p/n as the 02 sensor located at front of the engine(the one that's looking at you when you open the hood)?
Old 12-19-2007, 03:55 PM   #10 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
Yeah, bank 1 is near the firewall. Your best bet is to call a dealer and ask them for the part # first if you are going to order one elsewhere to make sure you get the same one.
And yes, the trac light will come on in tandem with a powertrain code. Replacing that o2 sensor should take care of it.
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline   Reply With Quote
Old 12-19-2007, 04:08 PM   #11 (permalink)
jet2757's Avatar
thanks for the information.
EglinAFB? I was a 43152. C-130. Born at Ft walton beach..
Old 12-19-2007, 04:53 PM   #12 (permalink)
Qslim's Avatar
Cool. I strap things to f-16s that go boom, and then try to figure out what went bad when they inevitably don't.
-- Get him, boy....
Old 12-22-2007, 01:59 AM   #13 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $398760
iTrader Score: 13 reviews
the traction control light coming on has nothing to do with the o2 sensor
the hesitation is the tranny going nuts trying to figure out traction control and then turning it off since it can't seem to figure it out...it's a good time to buy a good code scanner now that can read pending codes, as from my experience, this has to do with a shift solenoid issue. sometimes it will throw a CEL along with it, and sometimes it will be pending and then go away.
I actually have this same issue on my solara right now, and I have to replace my shift solenoid but haven't gotten around to it yet though
HaHa
Old 03-10-2008, 12:23 PM   #14 (permalink)
ksexton13
View ksexton13's Photo Gallery
Misfire
I am having the same problem, but am getting cylinder misfires. I guess this would go along with the Traction Contol shutting off to save power, since I get major hesitation in reverse and around 2100-2200 RPM.
If the O2 doesn't fix it, let us know!
ksexton13 is offline   Reply With Quote
Superpro/Whiteline Group Buy due to North America wide Price Increase raptorracing Supporting Vendor Sales 51 07-22-2009 11:12 AM
trac control jmax 2nd Generation (2007+) 2 09-08-2007 04:26 PM
R.I.P. Toyota Camry Solara? lexusis350 Toyota News 68 07-07-2007 05:32 PM
EVAP Canister Code stir_fry_boy Camry & Solara Lounge 9 05-24-2006 06:04 PM
