Originally Posted by ebbob
I own a '99 Toyota Solara and it seems that both low beams went out at the same time. Is this possible?
EB,
While it's possible for both bulbs to go out fairly close to each other (bulb life is measured in hours) it's more likely you've had one low beam bulb out for awhile and only noticed you weren't putting 'any' light on the road when the second bulb went away.
I don't know if the GenI Solara has a separate fuse for the low beam (check your owners manual). If so check the fuse first. If that's good and if you have a continuity tester it's simple to remove a bulb and check it. No continuity? Replace the bulb.
A last ditch way to check a bulb (because it's easy to burn yourself) is to remove it and connect directly to a 12 volt source.
Cheers
