First, you need a service manual so you can see what's involved. The EGR codes MAY simply reflect a dirty or lazy EGR valve. It's relatively simple to remove it, clean it, and reinstall it. If it's stuck open, which I have a feeling it is, you may have to replace it altogether. Either way, you need a new gasket. Pick one up before you begin. Has the O2 sensor ever been replaced? At 191K miles, it's probably shot. Again you need the manual to find it. You may need a special socket to remove and replace it, about $10. Cleaning/changing the EGR valve and changing the O2 sensor aren't difficult and you've got little to lose. Check in the manual how to clear the codes. You may have to disconnect the battery, reconnect it, and then drive the car through a "learning" sequence of up to 25 miles at varying speeds before you can even try to take the OBD test. After all that, you may still have the codes. At that mileage, anything's possible, but what have you lost? Do the replacements with the engine cold. Those two parts get really hot. Good lluck.
